Voltage surge at start-up
Old Dec 25, 2001 | 09:17 AM
NoWorries's Avatar
NoWorries
Default Voltage surge at start-up
Year - 1987
When I start my car, I see 14.4-14.5 volts, for about a minute. After the car warms up, it goes to a much more comfortable 13.9 volts.
Is this caused by the cold? The highest temperature I've started it at in the last two weeks was 40 degrees F, most temps are much colder.
I don't want to split the battery, is there anything I can do? My roomate said he heard something about an adjustable zeniar(sp?) diode, so that you can regulate the voltage coming out of the alternator. Is 14.5 volts going to hurt anything if its only on for a minute? Thanks.
Old Dec 25, 2001 | 11:44 AM
jfb's Avatar
jfb
Default Re: Voltage surge at start-up (NoWorries)
Its just a start up transient and will not harm the battery or the alternator. My 87 doesn't do this , but your alternator has this quirk. The alternator is designed to maintain 14.3 to 14.7 output volts but does not have tight temperature compensation and as the alternator warms up its output voltage falls to about 13.3 volts or thereabout. The alternator regulator also has output current limiting to its rating (105 amps) and achieves this by decreasing its output voltage to limit the current to 105 amps. Yes there are adjustable zener circuits (not really a zener diode, but an integrated circuit) , but since the voltage regulator is a molded device, adjustment of the voltage control circuits is not possible. Also, connecting an external zener across the alternator to limit its output voltage would cause high currents when the alternator is trying to put out a voltage higher than the zener is set for (like when you first start your car). Just do as Bugs Bunny says, "Unlax Doc".
Old Dec 25, 2001 | 12:40 PM
Red Dwarf's Avatar
Red Dwarf
My 95 does the same thing, 14.7 at startup & usually drops to 14.2 after about 20 minutes. Has been doing that forever. Sounds normal to me.
Merry Xmas.......
Old Dec 25, 2001 | 01:38 PM
foxspy's Avatar
foxspy
With my truck, when I start it my gague reads about 14-15 volts, but when it warms up, it drops down to about 10 at idle, due to my underdrive pullies. But the reason for mine being that high when I first start it is cause I told my computer to idle higher at colder coolant temps. I'm assuming the stock computer does the same, so if the engine is turning more revs at colder temps, then the altenator is also turning faster, producing more volts.
Old Dec 26, 2001 | 01:27 AM
black86targa's Avatar
black86targa
when you use the starter, especially in cold weather, starter takes off the 'top' charge on battery, so alternator will charge higher than normal for a few mins till it replaces that. Then goes back to normal charge. Anything in the 13.5-14.5 volt range is considered normal.
Old Dec 26, 2001 | 09:20 AM
89 Bob L's Avatar
89 Bob L
WHat your are experiencing is normal. The starter takes a heavy draw of amperage from the battery, especially if it is cold (or extremely hot). Once the aperage is drawn (the car is started and the starter off ) the alternator attempts to replace the amperage/voltage back into the battery in a quick and efficient manner. As the battery is recharged the amperage needed is reduced. 14.7 initial voltage dropping down to 13.3-13.7 is ok.
Old Dec 27, 2001 | 02:07 AM
NoWorries's Avatar
NoWorries
Default Re: Voltage surge at start-up (89 Bob L)
Thanks for all the great replies. You all really made it easy to understand. :)
To Voltage surge at start-up
