coolant change
Old Jun 29, 2008 | 11:47 PM
zmanz1's Avatar
zmanz1
Default coolant change
hi all , can anybody post a link on how to change the coolant in my 96 lt1 auto , which coolant should i use thanks
Old Jun 30, 2008 | 12:19 AM
94z07fx3's Avatar
94z07fx3
Factory Service manual proceedure with embelishments:
https://www.corvetteforum.com/techti...D=53&TopicID=2
This tool sounds like it would make life easy.
https://www.corvetteforum.com/techti...=222&TopicID=2
From the FAQ
Fluids:
Coolant - Prior to 1995, all Corvettes came with GREEN coolant. Do not mix Dex-Cool with conventional green coolants, or it will cause the mixture to become jelly. It's a real mess to clean up. There are new coolants that are compatible both ways, they are ok.
Old Jun 30, 2008 | 09:09 AM
aminnich's Avatar
aminnich
When refilling be sure to purge the air using the bleeder screw on the t/stat housing, engine running, and bleed again after reaching op temp and t/stat open.
Old Jul 1, 2008 | 12:01 PM
93lt1fun's Avatar
93lt1fun
Check out Evans Cooling Sytems http://www.evanscooling.com/index2.html
They invented the LT1 reverse flow system!
I run Evans coolant with no thermostat and 7lb cap.
Old Jul 1, 2008 | 07:10 PM
staugur's Avatar
staugur
Not very technical but it works.........open the drain plug on the rad,should be bottom right.Stick a hose in the filler cap and regulate it so the water in equals water coming out.Start it up and let it idle for ten minutes.Turn it off, and after it's finished draining fill it with green stuff.The block won't drain,neither will the heater,so you probably end up with a 50/50 mix.If you're not in Alaska that's probably good enough.
Old Jul 1, 2008 | 07:28 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Use distilled water, never public water, or worse, well water.
To coolant change
