I used to get consistently over 30 mpg. Then I took the motor/transmission apart and now I'm getting a best of 22 mpg.
Here's everything I've thought to look at. I'm replacing the O2 sensor Friday, although I don't think it needs it.
- 2600 stall torque converter, lock up confirmed
- O2 sensor, new when I bought the car 4,000 miles ago
- Tire Pressure, 35 psi all the way around
- Cam Shaft, slightly hotter than stock, nothing much
- Compression, 10.78:1 Does this make a difference? I'm running 92 octane
- Spark Distribution, All new as of 900 miles ago
Re: Trying to track down mileage problem. (NoWorries)
I don't think there's anything wrong with you car. I highly doubt you were getting 30 mpg before no matter what the gauge says. The new C5's are more efficient than the C4's and they were getting about 26 mpg.
Re: Trying to track down mileage problem. (Romeo Barrera)
Romeo,
I don't trust the dash, never had. The best calculated mileage I ever got was 31 mpg on the downwind leg towards Phoenix from the Grand Canyon. On the reverse trip(more hills), I got 28.
Now, on the way to Phoenix, I pulled off 22, calculated. The dash thought I got 37. :eek:
Is that the same convertor you had or is it a higher stall speed? I doubt the tire pressure is causing that much loss, but I try to run 32psi cold. What are your cam specs?
Since some are doubting if you really have a problem, you might clean/check your tailpipes to see if they are getting a lot more carbon buildup than normal. That might be an indication that you really are running too rich.
Are you basing the mileage on actual calculations or the readout? The readout will not be accurate if you changed injector size.
If everything is working right, it should correct the fuel trims to their correct values for optimum mileage. The best way to figure it out is with a scan - any chance you can do that and let us know what it says?
Re: Trying to track down mileage problem. (olephart)
Since you've had the engine out recently, go back and check the vacuum line going to the fuel pressure regulator. My mother's car was getting crappy mileage and I found the hose was split on the back side where you couldn't see it. Could be something simple like this.
Check the fuel regulator as mentioned. Recheck the timing too. Its also possible the motor has not completely broken in. Did you go to a lower temp thermostat. That could account for a loss of mileage. The cam you have is a bit larger than the stock one so you maybe losing some mileage because of it as well. 10% is possible.
New motor...new "HOTTER THAN STOCK CAM"...Hehehehehe.
Does that answer the question for you?
One thing is a lot of people make a mistake of setting the valves too tight, especially with stock hydraulic roller lifters ( unless you have stiff springs, going more than 1/8 turn past zero lash is a BIG mistake ). The tell tale signs of over tight valves are a slightly rough idle when in gear and uneven firing sensation on acceleration.
Higher compression will usually help mileage.
One note is with these mods, you may not really help performance that much with the stock ( read: "JUNK" ) overly restrictive exhaust manifolds. Putting even shorty headers will amaze you in the difference.
A big place to pick up mileage is to have a chip burned with less total ignition timing, so you can bump up initial timing and crusie timing without hi rpm preignition.
Other than that, speed cost money...if not parts, then gas ( or usually both )
Cam- 214/220 .452/.465 center angle 112
Torque Converter- 2600 stall, lock-up provisions
Lifters- Crane Hydraulic Rollers
Rockers- Crane Roller Tip
Springs- Matched to cam-shaft, I don't remember the specs
Exhaust- Hooker SuperComp 2.5 inch exhaust, single Dynomax muffler.
My cheap air/fuel ratio guage says I'm running a little rich, but I not much.
I wanted to get a new top-end before I got a chip burned, I think I'm in a no-win situation with that, other than getting heads/intake then getting a chip burned.
I can live with this for now, I just expected to get at least 26. I'm calculating the mileage from gallons used and mileage traveled. I quit trusting the dash a long time ago. The only things its good for is putting it in neutral at 75 mph and showing your pax 86 mpg. :D
You can also negatively affect your mileage with faulty cylinder firing. If any one (or more) cylinders decides to slack off (bad wire, etc), the engine still turns the same speed at the same MPH, but the remaining cylinders have to work harder, while the slacker cylinder still has gas flowing through it.
Lee
Maybe your foot got heavier since your motor change. I only get 16mpg city/highway and 22highway. When my foot gets really heavy the mpg gets down to like 10mpg.
