1984
Old Jun 30, 2008 | 10:43 PM
poppop's Avatar
poppop
Default 1984
Found very clean and very complete 1984 vette. Has been sitting 14 years. Got it home and doing the normal stuff before starting. Gas tank seems full . Is there any other way to drain it other than dropping the tank ???
Old Jul 1, 2008 | 08:48 AM
kalister1's Avatar
kalister1
You could siphon it out? Or maybe disconnect the fuel line under the hood and let the pump empty it? The ALDL connector under the dash can be jumpered to run the fuel pump. I am not sure what pin needs to have 12 volts put to it, I know it is on here someplace.
Old Jul 1, 2008 | 09:03 PM
poppop's Avatar
poppop
Thanks for the reply. Will give it a try
Old Jul 1, 2008 | 09:18 PM
Road Agent's Avatar
Road Agent
Old Jul 3, 2008 | 02:19 PM
C4happy's Avatar
C4happy
It is usualy by the fuel pump relay and it is a single wire green connector and it is inches from the relay
To 1984
