How To Manually Control 4+3 Overdrive
Old Jul 2, 2008 | 08:56 AM
88espo's Avatar
88espo
Default How To Manually Control 4+3 Overdrive
i HAVE A CARB SET UP AND NEED TO MANUALLY RUN MY OVERDRIVE. CAN I GET Thanks
Old Jul 2, 2008 | 09:03 AM
rodj's Avatar
rodj
Disconnect the wire from the ECM to the O/d relay ( make safe ) and wire a switched 12V feed to relay.
Switch now turns O/d off - on like ECM did.
Old Jul 2, 2008 | 10:42 AM
lead foot 85 vet's Avatar
lead foot 85 vet
The ecm just grounds the trans relay to kick it in overdrive..........so you just run a gound though a switch to the transmission relay.....I think it's the green wire.
Old Jul 2, 2008 | 06:32 PM
88espo's Avatar
88espo
Thanks, but I have no computer. What can I do to operate?
Old Jul 2, 2008 | 11:01 PM
lead foot 85 vet
you'll need a wiring diagram of the overdrive relay...........then just ground the wire which would normaly come from the ecu with a switch you install......waa laa.....you shift into over drive with the switch instead of a computer.
Old Jul 3, 2008 | 04:02 AM
rodj's Avatar
rodj
Brain fart ; too late at night
Old Jul 3, 2008 | 05:27 AM
88espo's Avatar
88espo
I had it working, but then for some reason it quit! I put a hot 12volt lead directly to the solinoid to listen for the click and I can't hear it. Did the solinoid burn out? How can I test it? Thanks
To How To Manually Control 4+3 Overdrive
