Corsa Exhaust leaking!
Old Dec 25, 2001 | 09:39 PM
SLOWBUSA's Avatar
SLOWBUSA
Default Corsa Exhaust leaking!
I have a small leak in the bottom rear of both mufflers.:eek: Is this normal? I bought the exhaust new, so it has not been damaged by me. Also, I can't seem to get the clamps to seal the joints or junctions of the pipes.:crazy: I have torqued them down fairly tight, but they still leak. This leaking is making the car run a little rough. I tightened everything down, and it runs better. Do i need to have the system welded or am I missing something as to tightening the the clamps.:confused: Is the exhaust system under that much pressure? Any help wouid be appreciated. Thanks.
Old Dec 25, 2001 | 10:47 PM
kkonen's Avatar
kkonen
Default Re: Corsa Exhaust leaking! (SLOWBUSA)
I have a Corsa with the same problem. I went thru every bolt and torqued them all down. I don't worry about it now. If you think that it is causing the engine to run rough then have it welded. An exhaust shop can do this for you for under $50.
Old Dec 25, 2001 | 10:57 PM
MarkBychowski's Avatar
MarkBychowski
Make sure the pipes are inserted all the way into the flange. The pipes fit pretty tight, so it's possible they're just not in all the way.
Old Dec 25, 2001 | 11:30 PM
SLOWBUSA's Avatar
SLOWBUSA
Default Re: Corsa Exhaust leaking! (MarkBychowski)
Do you mean insert the pipes until they reach th back of the expansion slots. I fit the exhaust, so that the pipe being inserted only left a little of the expansion slots open on the slip over pipe which I figured would be covered by the clamp. Do I need to push each pipe till it reaches the end of the other pipes expansion slots? Is the leak in the back of each muffler normal(there is a little hole in the back of each muffler that drips water when first started:eek:) ? Thanks for the help. :D
[Modified by SLOWBUSA, 9:32 PM 12/25/2001]
[Modified by SLOWBUSA, 9:33 PM 12/25/2001]
[Modified by SLOWBUSA, 9:35 PM 12/25/2001]
Old Dec 25, 2001 | 11:47 PM
MJ's Avatar
MJ
(there is a little hole in the back of each muffler that drips water when first started:eek:) ]
It's there to drain condensation till the system comes up to temp. The stock mufflers have the same hole.
Old Dec 25, 2001 | 11:51 PM
SLOWBUSA's Avatar
SLOWBUSA
Default Re: Corsa Exhaust leaking! (MJ)
Thanks. :D
Old Dec 26, 2001 | 12:40 AM
Mike92's Avatar
Mike92
Welding it would definetely get rid of the leak. Do you like your exhaust? Also, did you ever run the 1/4 mile before and after the exhaust and or pulleys? Did the UD pulleys give you a SOTP difference at all?
Old Dec 26, 2001 | 12:47 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Corsa Exhaust leaking! (Mike92)
Forget the clamps...weld that sucker! :cheers:
Old Dec 26, 2001 | 06:08 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You should have the expansion openings completely closed. You can weld it but removing it means you'll have wrestle with whole thing and you can forget about reselling it since you won't be able to ship it. Mine has been on the car for 11 months with no leaks.
Old Dec 26, 2001 | 12:50 PM
silver & red CE's Avatar
silver & red CE
Do you mean insert the pipes until they reach th back of the expansion slots....Do I need to push each pipe till it reaches the end of the other pipes expansion slots? Is the leak in the back of each muffler normal(there is a little hole in the back of each muffler that drips water when first started:eek:) ? Thanks for the help. :D
I pushed mine all the way in, everything fit fine. It gets close to the differential (at the rear of the resonantor), but I never have had any trouble after >5K miles.
The weep hole is needed to drain H2O out of the system in case you don't run the car long enough to boil off the exhaust H2O in the muffler.
Eric
Old Dec 26, 2001 | 12:52 PM
Chris@SD's Avatar
Chris@SD
That is most likely the condensation drain that you are referring to. It is supposed to be there. A leak that far back in the exhaust will not effect the way the car is running. It will have to be before or right around the O2 sensor to cause any realy problems.
Just a reminder.... we are having an UNBELIEVEABLE sale on Corsa C4 exhaust until the end of the year. This is only on in stock systems. Once they are gone, the sale is over. :)
Old Dec 27, 2001 | 11:22 PM
SLOWBUSA's Avatar
SLOWBUSA
Thanks for all the responses. :D Is it possible that the exhaust leaking is causing the service engine light to temporarily come on and the car to run rough. It feels as though the exhaust gas is coming back up the pipes at cruising speeds especially at about 50mph in 3rd gear. This is usually when the light will come on. :confused:
Old Dec 27, 2001 | 11:29 PM
SLOWBUSA's Avatar
SLOWBUSA
I don't race the car, but I do like the exhaust. I don't think it makes as much power as the B&B Triflo. The B&B would push me into my seat harder than the Corsa, but it was just too loud. I still have the B&B in case I install a better gear in the rear end. As far as the pulleys go, no SOTP difference. The car does seem to pull harder at higher speeds than before. I have only had the car to 135mph, but it was still puliing hard at this speed. I am only running the crank pulley because the two pulleys together let my voltage drop to low. Also my idle dropped after installation to about 500rpm where it used to idle around 650 to 750. Hope that helps. :yesnod:
Old Dec 28, 2001 | 12:02 AM
VMAX451's Avatar
VMAX451
Mine leak slightly at the joints too. I tightened the clamps to spec and have all the joints fully seated but it still leaks a bit. I re-tightened several times cold and hot but it didn't help. There's some exhaust joint sealant that I've used when clamping other exhausts together that solves this problem, but the Corsa instructions didn't mention using it so I didn't bother. Welding it would solve the problem but if you do it make sure you go to someone who knows how to weld stainless (i.e. be wary of any chain muffler shops).
Old Dec 28, 2001 | 12:18 AM
SLOWBUSA's Avatar
SLOWBUSA
Default Re: Corsa Exhaust leaking! (Vince Ivanc)
I still don't understand how it can leak fully seated with the clamps tightened. Has anyone checed the back pressure on the Corsa. You would think the exhaust gas would go the path of least resistance. :crazy: :confused:
Old Dec 28, 2001 | 01:09 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
He said..."Insert" Weld them, problems will be over!
:lol: :lol: :lol: ;)
[Modified by eamador11, 11:09 PM 12/27/2001]
Old Dec 28, 2001 | 11:31 AM
Mike92's Avatar
Mike92
Check Speed Demon and no special on Corsa :(
Old Dec 28, 2001 | 07:04 PM
rbhighrise's Avatar
rbhighrise
St. Jude Donor '03-'04-'05-'06-'07-'08
What? Just purchased one five minutes ago. :confused:
Old Dec 29, 2001 | 03:44 AM
Mike92's Avatar
Mike92
I went to the web site and there wasn't a corsa exhaust in the specials section. Throught the motor mall there is one for 850 though. ;)
To Corsa Exhaust leaking!
