90 fuel sending unit: Are they rebuildable? Mine is beginning to act up.
More info needed Achille....
Define act up?? What's estimated mileage on this bad boy?
You can buy the whole taco for $199.99 sans pump..NOS guaranteed OEM GM from Corvette Recycling-(801) 447-4700.
Some like to screw around w that variable resistor (remove & clean pointer etc.)
While your in there replace the pump.(your call) Another $88 from your local AUTOZ. Delphi made in Mexico. Don't forget the tank gasket. I'm probably dumber than you.... whole deal took me an hour.
Cheers
Check your 6
