starter motor
Old Jul 3, 2008 | 09:18 AM
jhm9380's Avatar
jhm9380
5th Gear
Default starter motor
NEED HELP,
I changing the starter on my 1984 Vette. There is supposed to be a brace that supports the rear of the starter. I have the brace, but I cannot figure out how/where it bolts to on the engine block.
Thanks in advance for any help
Old Jul 3, 2008 | 03:04 PM
JonnyAngle's Avatar
JonnyAngle
I don't know bout your 84, but my 86 only has the 2 bolts holding it on and it runs fine.
Old Jul 5, 2008 | 06:12 PM
jhm9380's Avatar
jhm9380
5th Gear
I have the shop manual for the 84, it shows a brace but its not very detailed on where to connect to on the block
Old Jul 6, 2008 | 01:13 AM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
If it is anything like the 85 it bolts on the block by the exhaust manifold and on the starter. I just had mine out to replace the solenoid.
Hope this helps
Mike.
Old Jul 7, 2008 | 05:56 PM
jhm9380's Avatar
jhm9380
5th Gear
Mike, Thanks
I thought that might be the place on the block. but I cant get a bolt in the hole with the exhaust manifold in place. Dont know if there should be a stud type bolt installed before the manifold was installed. However the starter seems to work just fine without the bolt.
PS: had the motor replaced and finding a lot of little thing that are not right.
To starter motor
