Does a stock 90' ECM have a rev limiter?
Dec 26, 2001 | 11:11 AM
Cruise-In VII Veteran
St. Jude Donor '07
What is it set at? Thanks
Dec 26, 2001 | 11:21 AM
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Re: Does a stock 90' ECM have a rev limiter? (Budman78)
fuel cutoff is at 10,031rpm with fuel resume at 9544 rpm. Of course, these vaulues can be changed if one needs more room to work with!!
Dec 26, 2001 | 02:55 PM
St. Jude Donor '07
Re: Does a stock 90' ECM have a rev limiter? (Marcho Polo)
:eek: :eek: :eek: 10,000 wow.
Dec 26, 2001 | 07:16 PM
Former Moderator
:yesnod: I don't think it's meant to be used!!!! :D :D :D :D
Dec 26, 2001 | 10:29 PM
...And that's in conjunction with fuel cutoff at 255mph...And fuel resume at 227mph...
...I think these are pretty realistic...Don't you??? :crazy:
Dec 27, 2001 | 12:07 AM
St. Jude Donor '07
Re: Does a stock 90' ECM have a rev limiter? (Rich B.)
I guess I'm going to have to upgrade the brakes now. 227 mph. The reason I was asking was:
1) I was hoping I had a rev limiter for the NOS.
2) I was experiencing some cutout at high revs. I guess it is valve float or fuel stavation.
No NOS, until all is well to 6,000 rpm. My decor plate was coming off the other day, so I may also have a vacuum leak also.
Dec 27, 2001 | 09:18 AM
Reprogramming the RPM limit in the chip should work. I have mine set lower (4800 I believe) but have never hit it.
Dec 27, 2001 | 10:54 AM
Former Moderator
problem with this is the chip only controls fuel cutoff.... if you are on the bottle and all of a sudden there is no fuel.... well, it's not pretty!
Best way to control revs are with ignition cutoff.
