caliper bracket bolt stuck??? help
Old Jul 5, 2008 | 05:58 PM
ELVIS' C4's Avatar
ELVIS' C4
From: Sugar Land, TX (suburban Houston area) U.S.A.
St. Jude Donor '09, '13
Default caliper bracket bolt stuck??? help
Hi all:
First brake job on my 92...the 2 caliper mounting bracket bolts are on disgustingly tight. I even am using a tight fit 13/16" & even w/ hammer wacks & a liberal dose of liquid wrench nothing is budging??
Anyone have any other ideas??
FYI...I'm taking the bracket off as I have a new set of discs for the front & a new caliper.
Help??
thanks!
Old Jul 5, 2008 | 06:05 PM
StealthLT4's Avatar
StealthLT4
Yeah, they're a PITA. A 1/2" Socket wrench, lots of PB-Blaster and a Sledgehammer is what got mine out.
Old Jul 5, 2008 | 07:05 PM
Cyclonite's Avatar
Cyclonite
Cheater bar (3' piece of pipe) on a 1/2" breaker bar after letting PB blaster soak for a while.
Old Jul 5, 2008 | 07:20 PM
Sidney004's Avatar
Sidney004
Follow the advice above. Somebody must of used red loctite on it last time. Only use blue loctite.
Old Jul 5, 2008 | 07:31 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Leverage is key...use the longest bar you can get in there.I bought several different length breaker bars for various jobs.Save my **** many times.
Old Jul 5, 2008 | 08:18 PM
John A. Marker's Avatar
John A. Marker
Be sure to use a 6 point socket rather than a 12 point. PB Blaster and let soak over night.
Old Jul 5, 2008 | 08:29 PM
bobmic93's Avatar
bobmic93
I had to do this today!
Old Jul 6, 2008 | 12:16 AM
ELVIS' C4's Avatar
ELVIS' C4
Okay...I borrowed a long handle socket from my neighbor & we both worked it a while & "finally"!! Leverage is my friend. I figured worst case I would have been at Home Depot buying a piece of pipe but the long handle worked nice!
Good news is the new calipers (painted red) & new disk look really nice!
I was so exhausted when I finished the other side just a few hours ago I jumped in the pool & figured I do the brake flush tomorrow. Have a new tool "toy" from Griot's Garage...the reservoir to flush the entire system...look forward to trying it out tomorrow!
Thanks all!
Old Jul 6, 2008 | 12:18 AM
ELVIS' C4's Avatar
ELVIS' C4
And i got to play w/ my new torque wrench re-installing those caliper bracket bolts!
Shameless plug here for my favorite "cheap tool" place...Harbor Freight!
To caliper bracket bolt stuck??? help
