383 build finally underway
Short block build specs are as follows:
Callies Dragonslayer Crank
Manley H-lite H-beam rods (6" long)
Mahle flat top coated pistons (-5 cc reliefs)
Bret Bauer cam (CompCams lobes) 230/242; .603/.586 w/ 1.6 rockers; 111.5 LSA
Cloyes Street Roller timing set
4 bolt truck block; 0.005 piston to deck, .044 total quench
10.8 SCR with 65 cc heads
Top end parts include AFR195 Eliminators that I am porting and a ported FIRST intake. I will have the heads (and perhaps the intake) flowed when the porting is complete.
I haven't totally decided on the headers yet (4 into 1 vs tri-Y), but the exhaust will be full dual 2 1/2" minimum with an x-pipe and cats.
I've run the combo through Engine Analyzer v. 3.3. Using the most conservative assumptions the program offers for dyno type and test speed, I'm getting 495HP @ 6000 and 510TQ @ 4000.
If all goes according to the current plan, I should be ready to fire it up by labor day.
Assume you pulled the engine & will install yourself?
Thanks.
I considered running 11:1 compression and tighter quench but I decided to be a bit conservative and leave myself some safety margin. My engine predictions are showing volumetric efficiencies over 100% in the 4000-6000 range, so I held back slightly on CR to make sure I don't run into a detonation issue.
Thanks.
Money wise, I budgeted $12K total. Thus far, I have spent $5300 for the AFR heads, FIRST intake, the rotating assembly, cam, and clutch/pressure plate/flywheel.
The machine shop estimate is $2000 for balancing, machining and assembly, but I'm guessing $2500 for the short block after I buy everything to complete it.
I'm estimating another $2000 for headers and exhaust plus an additional $500-750 for final dress items (water pump, small cap distributor, fuel lines and regulator, coolant hoses, etc.)
That puts me at about $10500, and I still will need a tune and dyno time. This could be done quite a bit cheaper but I decided I was going to do this exactly the way I wanted without compromise or I wasn't going to do it at all.
I know the car won't be worth that when I'm done, but I don't care. I'm the original owner and I'm doing this because it's something I've always dreamed of doing.
Todd. The reason why I ask about porting is because I talked to Tony at AFR, and my engine builder Jim who is well respected on the forum, and both recommended not porting the heads. Tony mentioned if I was dead set on porting to only send them to him, because a so-so head porter could do more damage then good. I kinda wish you didnt, I was looking forward to seeing your results with untouched AFR's.
I guess my motor with the big stroke will put these 195's to a major test.
Good luck with the porting, and post some pics!
I plan to build one - have a nice budget --but are you getting blocks
with distributor in rear and water pump in front - have a nice 95 LT 1 but hate the disrib and water pump together - could use some advise on that
len
I'm not expecting large gains, but I do think I will pick up a little more flow plus less potential for detonation.
Can you tell me more about the Bret Bauer cam ? Is that a hyd roller cam ? Is there a website I can have a look at ?
I apologize, but I am a little bit out of touch these days with the First intake system..... I have heard of the First intake and from what I could tell its a big bore tpi set-up..... is the intake fairly well proven nowadays ? Are there some proven set-ups with it nowadays? 495 HP is a lot of HP for a street 383, particularily with that style of intake..... and I would like to learn more about it.
On another note, good choice with those new eliminators..... nice cylinder head. And I do agree with the others, be careful modifying them.....
Good Luck with your Build-up !
The FIRST intake has been around for about 20 years, but it was only available as a full retrofit system (about $3 grand) until a couple of years ago. There are a couple of threads on the forum about it that have a bunch of information plus links to some threads on ThirdGen. The manufacturers website is www.firstfuelinjection.com. I will tell you this -- the pictures don't do the thing justice. The ports are HUGE. It looks more like a big block manifold.
