Broken Crank Pulley
Old Jul 7, 2008 | 07:33 PM
EC33's Avatar
EC33
4th Gear
Default Broken Crank Pulley
I was wondering if anyone had any hints/sugestions in regards to replacing a broken crank pulley?
Old Jul 7, 2008 | 08:54 PM
aboatguy's Avatar
aboatguy
Do not run your car.
You don't have a crank pulley on your car its the harmonic balancer/ vibration damper.
It is held on by 3 bolts and is a relatively easy fix. There used to be a couple fax on how to do this.
This link has TMI too much information since its an opti install but you can see the removal of the damper. and skip removing the opti. I have to pull the water pump to remove/replace mine but I have a Mez HD that may block more space than the stock pump.
MIke
Old Jul 8, 2008 | 12:05 PM
94z07fx3's Avatar
94z07fx3
Break the three bolts loose. Back them out one turn only. Start the car for 10 seconds or so only. The pulley should be easy to remove from that point.
Old Jul 8, 2008 | 12:16 PM
Chatman's Avatar
Chatman
How is it broken? It is separation of the outer rim from the hub?
To Broken Crank Pulley
