Engine Temp Question/Problem
So I took off down the road and it cooled back down as soon as I got air though it and felt normal/cool when I parked it. The other think I thought was odd was the oil temp was on the first notch but the electronic gauge was on 225? I assume I should believe the mechanical guages but whats my problem? Are there seperate senders for each? Is this a common problem?
with the car cool, check coolant level and assure it is just below the radiator cap recess.
There are two sensors, the one for the mechanical gauge is in the passenger side head/block. The other sensor, called the ECT, is what the engine computer uses, the digital dash uses, and is mounted in the water pump and is clearly visible just below the intake.
Check for corrosion on the connector by unplugging and replugging or a broken wire (actually 155 sounds like a base temp, as if the gauge has gone bad or a wire is broken).
If none is found, and if your reading was correct (155), and the difference between the two gauges remain, it implies the ECT gauge has gone bad.
If bad, do consider replacing it as the computer uses it to control everything about the engine, so if the computer thinks the engine is that cold, it could affect performance/efficency, etc.
