I have a 92 Lt1 that has an oil leak that I'm having difficulty tracking down. It does not leak at idle, but it leaks under load - right onto my cat. (then drips on my floor while parked).It's coming from the right side of the engine. It's not the valve cover gasket. I think it may be coming from the sensor mounted in the side of the block (mid-block near top, right side) - but I'm not sure...
Wipe it down as well as you can. Then go buy a dye/black light kit. You'll find the leak in no time.
Obviously I can't see the leak myself but it sounds more like the rear intake to china wall RTV.
This was leaking as well - I took the intake off and re-sealed it, and it's definitely not leaking here anymore -
Oh and if that sensor you've found has an identical twin on the other side of the block then that's the knock sensor.
I'll take a look at the driver's side tonight, and take pictures of the sensor in question...
I have cleaned the engine thoroughly then allowed it to dry, then driven the car. I've done this several times and thus narrowed it done to the one area. It slowly drips onto my starter while parked, and onto my cat when running under load... The dye / black light idea is cool - would I get that at an autoparts store? I've never heard of this approach to finding leaks...
I found the leak... The dipstick is a 3 pc item: the steel shaft, the cup that sits over the tube, then the handle. The cup is loose and does not seal on the tube, and the cup does not fit tight to the shaft either... I ordered a new one from Ecklers...
I had the same problem. Oil leak on the right making a mess and burning on my right cat. In addition, it was making a mess on my garage floor. Not a ton of oil but enough to make a mess. It was the rear seal on the intake manifold. I used Felpro gaskets and Permatex Ultra Black especially on the back wall which was the source of the leak. The removal of the intake was a breeze. Just be sure to make not of which bolts go where. Take pictures as you disassemble as there are a ton of vacuum lines etc. Also be sure to use a torque wrench when bolting the intake down. Don't over tighten.
