I have an interesting question that may require a tad of experience to answer. The car is an '89 L98.
I have the O2 in a well that is serves two of the four tubes of the headers. Not in the collector area. [ see the Tri-Y thread saga for picts of the exact location].
Antonio, my Exhaust Guru says the O2 sensor is calibrated to sense a mix of a bank of 4 cylinders [ as in bank firing F.I.] and predicts the end of the world if I don’t move it to the collector.
There is some logic [ and a lot of experience] on Antonio’s side...
BUT!!! That seems like more Magic Mojo than a little bitty sensor can deliver? I say sensor sees 14:1 gas mix ratio or the Computer makes a changes?
Who looses the bet?
TJM
[ I have a bad feeling about this, after reading what I just wrote? I think I’m out $25.00].
I agree with you, it doesn't matter the sensor will read 2 cylinders perfectly. Although I would prefere it to be a bit more "general" myself incase of an issue somewhere else other than the 2 its monitoring.
Who looses the bet?
TJM
you are ok. the o2 sensor works on a chemical reaction from the gasses that pass by it. It would not pick up a lean or rich mixture from the other cylinders. Most cars only have 1 o2 on 1 bank, that works fine. A balanced set of injectors really makes a difference with a single 02
I'm curious if you can read your BLM's for cell 0. I have seen when the 02 sensor cools off too much at idle, and the o2 sensor sees a false lean mixture. This is because the headers don't hold the heat like a true exhaust manifold.
C4 of Year Winner (appearance mods) 2019
It's time to stop listening to Antonio. He's wrong.
Vader86 has a great website that explains O2 sensors, installation recommendations for headers, info on all sorts of mods, etc... (He responded above). Click on his website (under his sig) and read the great links he provided and you'll know tons more.
Considering the design of the Tri-Y's, the location for the O2 bung is one of the things Vette Tech did right.
BTW Vader... A year or so ago, I complained about the lack of explanation on one of your links. After spending a LOT of time on the net during the past year, I found many of the posts/sources you've referenced. As a result, I really appreciate what you've compiled. And, I should apologize. You have just about the best (non-forum) websites for C4's I found. I refer back to it often.
This particular issue is more prevalent for headers that have the O2 in the collector, further away from the exhaust port.
Having it in a primary tube would actually help prevent reaching an open loop condition at idle in comparison.
O2's don't do much in a properly tuned motor, that has a good burn.
They just hang out waitin' for problems.
really ???
This is not as condensed as you make it sound, the proportional and integral fuel correction logic is complex. The proportional starts with the O2 sensor reading, and ends with a correction to the final calculated bpw. The proportional term always works in the opposite direction of the immediate rich/lean O2 sensor reading. The purpose of the proportional controller term is twofold. It is used to attain the desired AFR quickly. Second, it is used to maintain the switching of the O2 sensor about the desired AFR point.
Regardless of how "good the burn" (as you put it) is, based on the extent of the "look up" tables, there will always be some corrections being made.
PS: The two cops that passed me gave me a pretty sour looks, but no tickets [ on a 1.5 mile drive, what luck, both ways!! ]
It's not logical to spend that much.
I think you posted $500ish elsewhere? If he was going to install really nice hi-flow bullet cats and piping, it wasn't really too much. If it was just piping, then yeah.
