[PROJECT] Driveshaft Loop...
Old Dec 27, 2001 | 01:56 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default [PROJECT] Driveshaft Loop...
I put a driveshaft loop on the old Torque arm if anyone is interested to see how I did it. Pretty easy considering I already had the torque arm off the car ;).
Click here for the Webpage.
Old Dec 27, 2001 | 03:07 AM
GlockLT4's Avatar
GlockLT4
Default Re: [PROJECT] Driveshaft Loop... (Vette92)
Link isn't working.. :(
Old Dec 27, 2001 | 04:04 AM
BlackRocket's Avatar
BlackRocket
Awesome pictures and looks like a professional installation!!! Where did you get the loop? And, have you installed a scatter-shield???
Old Dec 27, 2001 | 04:34 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: [PROJECT] Driveshaft Loop... (BlackRocket)
Thanks BlackRocket...I do run with a RCI tranny blanket so I am covered there too ;). I just got the generic loop kit from Summit. I think it was about $20 and would do 2 Vettes.
Curtis, not sure why the link did not work for you. The EV1 server may have burped or something.
[Modified by Vette92, 2:39 AM 12/27/2001]
Old Dec 27, 2001 | 05:30 AM
Hawaii89vette's Avatar
Hawaii89vette
What does the driveshaft loop do? Is that a safety item so that the driveshaft don't fly off?
-Tim
Old Dec 27, 2001 | 08:03 AM
RichS's Avatar
RichS
Default Re: [PROJECT] Driveshaft Loop... (Hawaii89vette)
-Tim
Yes and it is required when running faster then 12.99 I belive.
Old Dec 27, 2001 | 09:07 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Chris, have you got that mounted forward enough????????
Looks like it's to far from the front u-joint???????
Old Dec 27, 2001 | 10:24 AM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: [PROJECT] Driveshaft Loop... (mackeyred96)
Great pics. Thanks.:)
:flag
Old Dec 27, 2001 | 10:58 AM
Nathan Plemons's Avatar
Nathan Plemons
That looks pretty awesome and very easy to do. It doesn't look like it would really affect taking the torque arm, driveshaft off. I learned that it's easier to do them both at the same time then to try and force one around the other.
I was kinda curious about the placement, I always thought it would need to be placed near the end, rather one on each end. But from looking at it, especially on the vette's short driveshaft, it looks like in the middle you would be fine. If either u-joint breaks it should keep the driveshaft from launching or otherwise seriously damaging the car.
BTW, I have seen these in Summit, if you could find the exact part number I'd be thrilled. This looks like an easy mod and something I want to do, I just want to make sure I get the correct loop, such that it fits as nicely as yours does.
Old Dec 27, 2001 | 11:34 AM
ConeKLR's Avatar
ConeKLR
Default Re: [PROJECT] Driveshaft Loop... (Nathan Plemons)
Watching a pole volter is cool..
Having your vette do the same is not.
This will happen or your rear end will get torn out if the safety loop is not far enough forward. It's safer to have the drive shaft drop down rear end first and go out back than have the front drop and dig in like a volting pole. NHRA or IHRA have specs on where to place it. :cheers:
Old Dec 27, 2001 | 11:42 AM
-=Jeff=-'s Avatar
-=Jeff=-
Cool Pics..
a part # would be great.. I need to install one on my car too
Old Dec 27, 2001 | 01:17 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: [PROJECT] Driveshaft Loop... (-=Jeff=-)
The Summit part number is SUM-G7900, cost $24.50.
John, I will be doing some final verifiction on whether it will function properly once I get it back on the car. I am almost possitive that the location in which I installed the device will keep the driveshaft out of the passenger compartment as well as keep it off the ground. Realize also that it would have to go ll the way through your exhaust before it ever sees the ground too. I installed it mostly to keep it out of the drivers seat in case something did happen. That is only fiberglass between you and that drive shaft.
Old Dec 27, 2001 | 01:18 PM
CFI-EFI's Avatar
CFI-EFI
Good job and good information. I do have a couple of concerns, though. NHRA rules state "...and located within 6-inches of the front universal joint for support of the driveshaft in the event of U-joint failure.". Besides the question of the NHRA rule, how tough is it to R&R the driveshaft with the loop so far back? I can't see a driveshaft escaping your set up, but the rules also state, "...a retainer loop 360 degrees of enclosure, 1/4-inch minimum thickness and 2-inches wide,". Does anyone know how NHRA has reacted to 180 degrees of this loop being aluminum? I think your loop meets the "spirit" of the rule (except for placement), but I wonder how far NHRA would carry this to the "letter" of the rule. Has anyone here had a similar loop inspected by NHRA?
PS. If you have any concern over the 6" requirement, you can always install the other half of the kit you bought, up front.
[Modified by CFI-EFI, 11:25 AM 12/27/2001]
Old Dec 27, 2001 | 01:21 PM
Thumper's Avatar
Thumper
Cool tech tip. Maybe some day I'll put one on mine. Also a few people have made the comment about breaking a u-joint and having the driveshaft dig into the ground, but on a C-4 corvette it will actually hit the exhaust first so that loop should work....although afterwards you'll need to get some exhaust work done :)
Old Dec 27, 2001 | 05:32 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: [PROJECT] Driveshaft Loop... (CFI-EFI)
CFI-EFI, our tech station barely looks at our cars when we go race. I have never been asked in the past if I was running a driveshaft loop at all. Mine is set bck 9 3/4" from the front u-joint so I am a little farther than the rule book allows. When I put it in a just knew I had to have one but not how fr it needed to be. The is plenty of room to move it up, plus I think there is also plenty of room to get the shaft in and out with the torque arm in place. I guess I will find that one out in a few days. ;) If need be, I will move it up, but for now, I think I will leave it as it is. Thanks for the rule info :D.
Old Dec 27, 2001 | 06:55 PM
Red Rocket's Avatar
Red Rocket
Chris, where are you mounting the parachute? :jester
Old Dec 27, 2001 | 07:34 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: [PROJECT] Driveshaft Loop... (Red Rocket)
I finished polishing the torque arm and the driveshaft looked a little pale so I had to do that too...here is a pic.
Also, here is a pic of my tranny blanket...a little worse for wear but functional.
I was thinking of the spare tire area for the parchute Dean :lol:.
[Modified by Vette92, 5:35 PM 12/27/2001]
To [PROJECT] Driveshaft Loop...
Old Dec 27, 2001 | 07:46 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
And of course you can't just leave the tailshaft all rusty...
Just had to try out the Hot Coat powder coater...
Old Dec 27, 2001 | 09:40 PM
CFI-EFI's Avatar
CFI-EFI
Chris,
A lot of good looking work, there.
I submit my car to NHRA certified inspectors at the beginning of the race season, each year. I get an ETI (Extended Tech Inspection). It is good all year long at any NHRA track in the country. It sure beats waiting in line every week for tech. If I claim I have a loop, they WILL inspect it. According to the 2001 NHRA rule book, a loop is required on a car running 13.99 and faster. The exception is 13.00 and slower on street tires. I took the liberty of submitting one of your photos (no, I didn't say where I got it) to the NHRA Division 7 Tech Director, and I asked if this would satisfy NHRA. I don't want to go to the expense and trouble, only to have it rejected. Frankly, I don't see how they could nix it. What else will fit under there? I'll report their answer, when I get it. That way we will all know. At this time, only MY name is on the line, and only in Division 7. Assuming that it passes, do you want to sell the other half of your loop kit?
Old Dec 27, 2001 | 09:47 PM
Nathan Plemons
You know that's just sick. So of course I want to do it. I know a guy who will powder coat mine for me. Next time I have it off he'll be doing that. Anyway, what did you use to polish your torque arm and driveshaft and how did you clean them to begin with. Details details details, I need details. It's things like that that tell people that you really are nuts about your car, I want people to think the same thing.
