Headlight alignment
Old Jul 9, 2008 | 10:39 PM
CStewTAMU's Avatar
CStewTAMU
Default Headlight alignment
I have taken apart my passenger's side headlight assembly again to try to fix the alignment issue.
I think my problem is that the entire assembly is loose somewhere.
When my driver's side headlight is closed, it is firm and doesn't move.
But when my passenger's headlight is closed, I can rotate it about 1/8th of an inch, then it falls back and sits 1/8th inch too low at the high side. How do you adjust or tighten the entire assembly where the headlight is firm and doesn't move? I just hope I didn't dammage anythign when I took the motor apart a couple of months ago-that little pin you have to take out didn't want to come out without a fight.
