Which one is easier to build?
Old Jul 9, 2008 | 11:32 PM
Nitelord's Avatar
Nitelord
Default Which one is easier to build?
I'm still looking for my first (drivable) corvette. The search is going well.
Anyway, my question is: Which engine is easier to build an LT1 or an LT4.
By that I mean the available after market go-fast parts. Stronger as in repeated runs down the strip. Able to handle the super charger, plus whatever else comes along.
Which would you recommend as a base to start with?
I realize this is subjective, but I'd like to hear your opinions.
Thanks, Mark
Old Jul 10, 2008 | 01:11 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Thanks, Mark
They are basically the same, so if you are planning on building one and doing a minimum of a heads/cam swap buy the best LT1/4 you can find. The only real positive of the LT4 is they are all six speed cars with a Dana 44 rear end. If you are going to build a serious LTX I can't see how it would make a difference. Supercharging a LT1/4 is not very common for a reason, you might want to research that a bit. If I wanted a supercharged Corvette I would look for a LSX powered C5.
Now before the LT4 guys go nuts I know what makes them different, heads, cam, more compression, 1.6 roller rockers, powedered rods blah blah blah blah and a nifty Grand Sport throttle body cover and red paint. I personally think the LT4 would be a better starting point if you did not want to do a whole helluva lot to one as they run really good with basic mods, gears, headers etc. If you are going to build a blown 396 stroker it won't make a difference.
Old Jul 10, 2008 | 04:38 AM
racebum's Avatar
racebum
the lt4 if you want to run mid 11s or slower
if you go hog wild it won't matter since everything will be replaced.
Old Jul 10, 2008 | 07:43 AM
Nitelord's Avatar
Nitelord
I won't be going hog wild yet. I understand about the supercharger. I've read both side of the story. I'm sure the setup will stay (as purchased) for a little while. I'm thinking if there was an appreciable difference, I'd go with the - upper hand now and build on it over the winter.
Thanks for the info so far... Mark
To Which one is easier to build?
