Universal Joint Bolts
Old Dec 27, 2001 | 08:54 AM
RJVette23's Avatar
RJVette23
Default Universal Joint Bolts
Could someone please give me the proper torque specs for the strap bolts on the universal joints. :confused:
Thanks in advance for the help.... :cool:
Old Dec 27, 2001 | 09:49 AM
scorp508's Avatar
scorp508
Something like 20 ft/lb is ringing a bell in my head, I'm not positive though.
Old Dec 27, 2001 | 03:13 PM
RJVette23's Avatar
RJVette23
Default Re: (scorp508)
Thanks Scorp....
I also found an archived reply that recommended 26 ft lbs. That's what I'll go with.
The Hayne's manual says...150 ft lbs :confused:
I snapped one bolt :mad , so I figured I should ask before breaking another.
Thanks again,
RJVETTE23
Old Dec 27, 2001 | 03:19 PM
scorp508's Avatar
scorp508
:confused: For the strap bolts? That sounds like the camber bolt.
Old Dec 27, 2001 | 03:24 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: (RJVette23)
You sure the Haynes manual didnt say 150 inch?I mis read a figure like that once.
Believe it or not,I never torqued mine down. I use the blue #2 thread locking compound(a Must) and tightened down hand tight.
Of course a month later I rechecked them and they were still snug.I had to use such a long extension,large ratchet,etc from outside the wheel wells doing the half shaft joints I didnt bother using the torque wrench.
I hope when you said you snapped a bolt, you got that one out?Btw, those bolts are about 3-5 bucks a piece from GM.One guy quoted me 7 bucks a piece! I then asked him if they take Medical Insurance cards.
Old Dec 27, 2001 | 04:30 PM
RJVette23's Avatar
RJVette23
Default Re: (Bill's86Coupe)
I'm sure it says 150 ft lbs for the "Universal Joint Strap Bolts" on the second page of chapter 8 in the Haynes....
I haven't removed it yet. I was too depressed to continue when it snapped last night. I'm going to work on it tonight. Wish me luck. I will be getting a new bolt tomorrow from the Chevy Dealer...$2.
RJVETTE23
Old Dec 27, 2001 | 04:42 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: Universal Joint Bolts (RJVette23)
I add Loctite and then usually torque them to "pretty f'n tight" and they have been fine.:)
Old Dec 27, 2001 | 06:59 PM
Aggravated4life
Default Re: Universal Joint Bolts (Fastguy)
I just checked my haynes manual,and in chapter 8 it says 150 In-lbs and NM is 17.
We got to be careful with those numbers..as I stated I misread a number like that as Ft-lbs and lucky I spotted a washer bending before I snapped the bolt and went back to re check and it was In-lbs.
Good Luck and keep us posted on the bolt that broke off.
Old Dec 27, 2001 | 07:12 PM
Ramrod92's Avatar
Ramrod92
Manual says 18 lb./ft. 150 is :crazy:
Old Dec 28, 2001 | 10:27 AM
RJVette23's Avatar
RJVette23
Default Re: Universal Joint Bolts (Ramrod92)
Thanks for all the replies. I'm going to pick up my new bolt today. I am also going to get a screw/bolt extractor. I had to remove the diff again to get a good angle on the broken bolt. I was able to drill into it straight enough to not damage any threads.
While I'm at the dealer, I'm going to get the torque specs for all strap bolts. As I have been working on this I think I have discovered that the drive shaft strap bolts should be 22-29 ft lbs and maybe its the half shaft straps that should be 150 ft lbs.
I'll let you know what I can confirm....:flag
Thanks again,
RJVette23
Old Dec 28, 2001 | 02:20 PM
6spd89's Avatar
6spd89
Same here-LOL
Pretty F'n tight works for me as well!!!!!!!!
Matt
Old Dec 28, 2001 | 02:45 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
JUST MAKE SURE YOU HAVE A GOOD SUPPLY OF SOCKETS ON HAND.
Old Dec 29, 2001 | 12:41 PM
RJVette23's Avatar
RJVette23
Default Re: Universal Joint Bolts (mackeyred96)
Update!!!
Check this out.....
GM Shop Manual for 1986 Corvette says:
Driveshaft - torque retaining strap bolts to 150 in. lbs. or 12.5 ft lbs
For Trunion straps at side gear yoke torque 26 ft. lbs.
For trunion straps at spindle yoke torque 26 ft. lbs.
This is what I'm going with. I'll let you know the results.
RJVette23
Old Dec 30, 2001 | 04:04 AM
GlockLT4's Avatar
GlockLT4
:eek: :eek: 150 in lbs perhapse!! :confused: :confused: wowwy!
Ah... hehe.. just saw the last post... yes, I would stick with around 25 or so... do NOT do 150ft/lb.. you'll break another lol.. that's :crazy: :crazy:
[Modified by Glock'94, 2:05 AM 12/30/2001]
Old Dec 30, 2001 | 05:11 PM
87SAM's Avatar
87SAM
Thought I saw that figure also.
Helms is in inch pounds
The Haynes manual does indeed say 150 ft/lbs :confused: :mad
To Universal Joint Bolts
