cam article 765hp blown 355
http://airflowresearch.com/articles/article122/A-P1.htm
following the link for the rest of the pages.
http://airflowresearch.com/articles/article119/A-P1.htm
Its difficult to make heads or tails of their results considering the pulley swaps, jetting and rocker changes.
To cut through it all, I plotted HP vs impeller rpm (4.10 D1SC step-up) for Test B and Test F which in my opinion are the most relevent tests. I'm too lazy to post the plot tonight, but I may update it later on.
Here's the plot using a 4.75" pulley as indicated in the table:
Test F has an edge all the way up to 43,000 rpm compared with Test B. As much as 60-80 HP is gained between 35,000 and 40,000 rpm in test F.
As expected, the reduced overlap of the hydraulic roller is making better use of the blower's airflow output for a given impeller rpm.
Reduced fuel consumption would also be an expected benefit with the reduced overlap hydraulic roller camshaft.
Looking into the data, Test F has a strange kink at the top resulting in a big loss of peak HP. This kink goes away in Test G resulting in much more power up top. I'd be surprised if this gain was actually due to the rocker change and not some sort of test issue.
Here's the plot again using a 4.75" pulley as shown in the table:
Note: There are quite a few inconsistencies in the article. Did they use a 4.5" pulley for tests F and G as indicated in the text and photo caption, or a 4.75" pulley as shown in the table. The data I have plotted above is for the 4.75" pulley. After re-reading, I think they really ran the 4.5" which changes the results considerably.
Here is Test F replotted for a 4.5" pulley:
This is a little more believable with maybe a 20 HP gain for the hydraulic roller at the mid-upper impeller rpms.
Here is Test G also replotted for a 4.5" pulley:
It is up to the reader to draw their own conclusions. The power that the D1SC can support at modest impeller rpms is impressive.
I also added boost vs impeller rpm to the 4.5" pulley plots. The boost vs impeller rpm curves are very similar between tests:
Here's what I learned:
1.) Less Valve overlap means you can use a larger pulley for the same boost and help avoid belt slip.
2.) 230/242 is considered a "small" hydraulic roller cam. I thought 230 was big for a 355ci with a blower, but I guess not.
can you run those plots for the 383 with 195's and a Vortec S-trim?
It's pretty close to what I'll be running, save the carb and the fact that I have an LT1.
I found it interesting that they left the compression ratio at 10:1 on a non-reverse cooled engine!
Granted they were on 105octane gas.
V1 with 3.45 step up:
V2 with 3.60 step up:
I wonder if they were measuring the D1SC boost upsteam of the intercooler or maybe even in the supercharger's volute???
I can imagine a sizeable pressure drop through the intercooler and carb, but is 6 psi or more a realistic drop? I would believe maybe 4 psi. Or does the D1SC suck up so much power in order to deliver 14 psi that it nullifies the gains. I can't imagine that the mechanical efficiency is that bad.
Any D1SC users care to comment on the boost vs impeller rpm or typical pressure drop?
The impeller rpm was obtained by multiplying the engine rpm by the overall impeller drive ratio for each supercharger or pulley combination.
