stumble at idle.
Old Jul 23, 2008 | 06:44 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
The IAC is right beneath the TPS.
Old Jul 28, 2008 | 06:23 PM
teebee's Avatar
teebee
Ok, I find that the fuel pressure should be a tad bit higher so I order a new fuel pump (AC DELCO from Superior Chevy), strainer and a new fuel filter. I get the FP/strainer installed-no change, the fuel pressures are exactly the same. So I go on and change the filter. While doing this I find that the #8 spark plug is a little loose, so I tighten it up as well.
Still not much different from before. It idles much better, but it still bogs when I rev it up, it has even back fired or "popped" a couple of times. No power, smells like it is running very rich.
I need some advice here, I am running out of options!
Old Jul 28, 2008 | 07:02 PM
cwyates4's Avatar
cwyates4
Haven't been following this thread, but those symptoms sound like mass air flow sensor or tps.
Old Jul 28, 2008 | 08:10 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Backfires are usually a timing or stuck valve issue. You know what does the timing.........(that we do not speak of)
Old Jul 28, 2008 | 08:19 PM
cwyates4's Avatar
cwyates4
Is the popping from the exhaust or intake?
Old Jul 28, 2008 | 08:36 PM
schrade's Avatar
schrade
Originally Posted by teebee1994
... smells like it is running very rich. ...
It IS running rich. And it is fouling everything with unburned gas.
I'm thinkin' ignition control circuit fault.
Do your dash lights flicker in sync with your idle miss? Watch VERY carefully...
Old Jul 28, 2008 | 09:23 PM
cwyates4's Avatar
cwyates4
What would the dash lights flickering with the stumble indicate? Every light on my car flickers when the idle is swinging low.
Old Jul 28, 2008 | 09:55 PM
teebee's Avatar
teebee
I'll be honest, I did not notice the dash lights flickering, but then again I didn't look at the dash lights while it was doing it. There have been no codes set other than the H43 which didn't surprise me since it was pinging along pretty good at times.
Popping came through TB. I was standing right there running the throttle by hand when it did it once.
Redeasy, yes I know and mine hasn't been on there for too much more than a 15 or 16 months maybe 6k miles.
Old Jul 28, 2008 | 10:38 PM
Redeasysport
Well you know it would not be unheard of for it to fail that early...unfortunately. Of course elminate everything else first. Good luck
Old Nov 4, 2008 | 11:51 PM
teebee's Avatar
teebee
Well guys (and gals), I just wanted to update this issue. I fought this for a while and I really can't even go into the entire saga, but I will say that I have finally resolved the issue.
Ultimately it came down to a bad optispark...this one was only 1 1/2 years old (less than 6000 miles). but as you can see in the picture the cap was toast and the rotor was shot as well. I could have gotten by with replacing the cap and rotor, but I decided that if I had it down that far I should replace the entire opti and I DID NOT go back with genuine GM, but chose to go with MSD. More money than GM, but I was not going to chance it again.
Jon Banner....I still have, at this point, the OE injectors in place. I think I am going to leave them in for now.
Old Nov 5, 2008 | 12:47 AM
DougSilver's Avatar
DougSilver
Bingo--I was wondering when someone was going to suggest "opti". Usually this happens by the second or third post and oftentimes the opti is not really the problem. It looks like this time it was.
Congrats for solving.
Doug
Old Nov 5, 2008 | 09:00 AM
teebee's Avatar
teebee
Doug
Redeasysport alluded to the opti but at that point I was still convinced that it was nearly new and expected genuine GM parts were better than that.
