will not start on first try
Old Jul 12, 2008 | 03:08 PM
squalsvette's Avatar
squalsvette
Default will not start on first try
Hey guys i have a 95 6 speed with 82,000. Car will not start, push clutch all the way to the floor turn key and nothing power is on and normal. Only after a couple of tries it will fire up and run fine. No codes...new battery,this just started a couple of days ago, can it be the starter or the security key or something with the clutch safety switch.No idea thanx for your help
Old Jul 12, 2008 | 06:36 PM
all show and more go's Avatar
do u have to give it gas to start?
Old Jul 12, 2008 | 06:53 PM
MikeC4's Avatar
MikeC4
check for tight connections on you starter. Sounds like the starter solenoid...be sure to disconnect negative terminal on battery first...
It could also be your starter motor starting to bite the dust....
Also could be, as you mentioned, your neutral safety switch is sticking.
To will not start on first try
