How much HP ????
Here's my combo; 1988 Corvette coupe (Z51), 4+3 trans rebuilt with roller bearings
-stock pistons, rods, piston rings and bearings (good compression on all cylinders)
-comp cams xtreme energy camshaft 218/224 @0.50
-comp cams valve springs recomended with the above cam
-comp dual roller timing chain
-comp thick wall push rods
-comp lifters
-mildly ported 113 casting heads (milled down 25 thousands, I think), back-cut ferra valves with 3 angle valve job, clearence for higher lift.
-felpro 1010 head gasket
-scorpion 1.5 roller rocker arms
-adjustable fuel pressure regulator
-Hooker long-tube headers and dual 3inch exhaust
-edlebrock aluminum water pump
-eldelbrock high flow runners and base plate
-ported plenium
-BBk throttlebody
-K&N air filther with open air box
-de-sceened MAF
well let me know what kind of HP numbers you think I'm running.
