Hey members,
I need to know which trans cooler line is the return line on a 90' Corvette coming out of the radiator, top or bottom.I dont have any fluid in the trans right now because I installed a Pete K. torque converter and I wanted to install a trans cooler before putting in any fluid.
Hmm odd, is it different per year? The top line at the radiator on mine is flowing toward the radiator. The bottom port on the radiator is flowing back toward the trans.
the way I did mine was,
I left the top line to the rad. alone. I have the bottom line going to the cooler, and from the cooler it loops back to the rad.
700R4 / 4L60 / 4L60E / 4L65E Technical Description
The 700R4 can be identified by the oilpan having a rectangular shape being longer front-to-rear than side-to-side and held to the transmission by 16 bolts, 3 bolts front, 3 bolts rear, 5 bolts left side, and 5 bolts right side.
The tailshaft housing is held onto the main case by 4 bolts (the bolt spacing is similar to the THM350), and uses a square-cut o-ring seal, and not a gasket. The typical width of this transmission where it bolts to the engine is 20 inches (510 mm) overall. From the engine/trans mating surface to the crossmember mount bolt is 22-1/2 inches (570 mm), and engine/trans surface to output shaft housing mating surface is 23-3/8 inches (594 mm) overall, with the tailshaft housing typically measuring 7-5/8 inches (194 mm).
Transmission fluid cooler lines on the 700R4 the bottom fitting on the right side of the transmission is the "out" line to the cooler and the top fitting is for the return line from the cooler. These fittings are 1/4-inch pipe thread, and CAN include an adapter from the factory for threaded steel lines in a SAE size. 4L60Es manufactured after 1995 use the modern-day snap-in connections as opposed to threaded SAE fittings.
The original version of the transmission had a 27 spline input shaft which was a common failure point. In 1984, 700R4s designed for use behind Chevrolet small block V8s received a 30 spline input shaft which used a different torque converter than its 2.8 V6 and 2.2 L4 powerplants. Between 1984 - 1987, internal components, from the ring gear to the oil pump housing, were updated, ending with the auxiliary valve body (for 700s manufactured after October 1986).
In 1995 the 4L60E received a PWM-controlled lockup converter.
Around 1996, a bolt-on bellhousing was phased in (along with a six-bolt tailhousing) when the transmission was bolted behind an inline four cylinder or the Vortec engine family.
The gearing for the 700 is:
First - 3.059
Second - 1.625
Third - 1.000
Fourth - 0.696
Reverse - 2.294
(commonly rounded off to 3.06, 1.63, 1.00, 0.70, and 2.29).
