Help CPS replacement
Old Jul 13, 2008 | 07:47 AM
rmc245's Avatar
rmc245
2nd Gear
Default Help CPS replacement
Hi Guys, I have a problem my CPS crankshaft position sensor is leaking and failed. I bought a new one at the GM dealer which for some reason is not the same? GM tells me its a modifiy sensor the problem is its twice the size (barrel end at go in the timing cover) but GM said it will fit but I could not see how you can put a larger barrel in a smaller hole. Has any run into this problem?
Thank you,
Bob
