hey guys sorry if this is in the wrong spot but i was takin the WP frisbee off today and noticed that the belt is too long ( unless i took off the wrong thing ) and i was just wondering if you guys bought a new belt how long was it. and also if someone dont mind could you post some pics of your WP frisbee delete.. thanks alot and sorry and i dont know what the hell im doing but ya gotta learn somehow
Added to balance the harmonics of the compressor - the Nippodenso compressor ('88 up) is quite a bit larger so make sure the back brace is installed. If you get vibration or noise, put it back on. Otherwise, some don't seem to have any problems with it gone and it was eliminated with the LT motors (though GM also changed the configuration of the accessory drive train).
Mine is now a bathroom key theft prevention device at a shop in my old hometown.
To frisbee removers:
be sure to add appropriate thickness washers to the bolts so they don't snag the pump.
About serp belts:
I believe sometimes a belt's part number is comprised in part by the number of ribs it has, it's length, and other factory info.
An example would be '89 vette belt pt. # 922K6.....92.2 inches, 6 ribs.
lol imma guess it was already taken off because all i see is the actual pulley... btw where is the tension release because i cant get my belt back on:o
The tension release is the belt tensioner, you can use a socket wrench or breaker bar to move it, not alot of room, you just put the breaker in the arm.
