8 Ignition Modules later
....1988 coup...90k milkes...terrific shape
and cannot figure out as to why this is happening....coil is new, rotor, cap, wires, etc all new........this is NOT an issue as to if the ignition module was installed correctly
or using enough heat sink compound because i did and have been all along..........could the capacitor under the distributor cap be taking the module out somehow?...i have not replaced that and cannot see arbitrarily being advised to replace that w/o reason...
........i had been using after-market stuff and all of these went...when i got the car, i took out the orig ac delco/gm module that was in it and replaced it while chasing down another problem....
....i put it back in yesterday and car starts up as in all the other replacements i have done...hell, there are guys on here that have never replaced nor needed to replace theirs in years and thousands of miles!...
...any informed suggestions would be appreciated!
...thanks for the reply....
"Do you know the difference between dielectric grease and heat sink grease? "..YES!, ABSOLUTELY!
"Heat sink grease is supposed to be put between the spark module and its mounting place.". .YES, I AM AWARE OF THAT FULLY!
"Heat sink grease is white, and dielectric grease looks like vaseline." ..YES, I AM AWARE OF THAT FULLY!
"Don't use dielectric grease in place of heat sink grease." ...NEVER DID AND NEVER WILL!
"One thing that can shorten the life of the spark module is to use an aftermarket spark coil and particularly ones that claim higher voltage. The spark control module is designed for a particular spark."
I AM USING A STOCK COIL AND ALWAYS HAVE.
You might try hooking up an analog volt meter and watching it as you drive. If your alternator is spiking your electrical system, it might be that the modules you speak of could be the most sensitive to electrical spikes.
Monitor your electrical voltage after:
1. first starting up
2. after a long idle such as a long traffic light
3. high speed blast
4. cruising speed
5. after turning on or off high current items such as the A/C. Or, A/C on, brakes on, cooling fan kicking on, headlights on, radio blaring.
6. If you have a speaker amp, it could be spiking your system as well
Another thing might be a sticky belt tensioner.
don't limit yourself to the failed unit as your subject of focus
....well, good for you!...wish i could say the same..however, the original ignition module that was once in the car and of which i put back in, took a dump about a week ago and it was gm NOT aftermarket!.....the current replacement is a gm module so, i'll see how long that lasts......will change out the capacitor assembly tomorrow and set a baseline to see how long this one will last!
3. high speed blast
4. cruising speed
WOULD LOOK ANOTHER PLACE AS WELL.
You might try hooking up an analog volt meter and watching it as you drive. If your alternator is spiking your electrical system, it might be that the modules you speak of could be the most sensitive to electrical spikes.**8 modules later and 1 original?...i can see the aftermarket stuff but, the gm stuff too?...the only thing left is the capacitor assembly which i will replace tomorrow...
1. first starting up **voltage will rise as the alt spins up to speed to recharge the battery and then will level off when no charge is needed. the alternator will "turn on" when the power requirements of the car require it to such as fans, a/c, headlights, etc.
2. after a long idle such as a long traffic light **see #1, i have no fluxuations in voltage that are noticeable and "spikes" would be so small and so fast that they would be undetectable for the most part.
3. high speed blast **can't see the relevancy in this
4. cruising speed **can't see the relevancy in this
5. after turning on or off high current items such as the A/C. Or, A/C on, brakes on, cooling fan kicking on, headlights on, radio blaring. **see #1
6. If you have a speaker amp, it could be spiking your system as well **nope, all stock and no amps, etc
Another thing might be a sticky belt tensioner.**nope, replaced the bearing about a year ago and inspected spring and all is well. don't see the relevance in this.
don't limit yourself to the failed unit as your subject of focus **believe me, i am not!..i carry a spare module with me at all times.
Do you have normal voltage when driving?(13 to 14.7 volts) YES Very high alternator voltage can shorten spark module life, like 16 volts or higher. AM AWARE OF THAT Heat is a real enemy of solid state circuits. Do you see anything in the spark module mounting that either won't allow heat to transfer from the module to the mounting? THAT WAS ONE OF THE FIRST THINGS I CHECKED BEFORE MOUNTING TO A CLEAN SURFACE AFTER REMOVING THE OLD COMPOUND WHICH SOME DO NOT DO Mount surface needs to be flat and in intimate contact with the module. IT IS Do you have unusually high engine temps, even only for short times? NO, NEVER GETS OVER 205* Is the spark coil also GM? YES An open circuit on the output of the spark coil will cause higher than normal voltage spikes on the primary which stresses the switching transistor in the spark module and shortens its life. Do you have a miss, rough idle? NO MISS, NO ROUGH IDLE BUT, GETTING READY FOR PLUGS SHORTLY!If so, you might check the resistance of each spark plug wire, they should be close to 5000 ohms per foot.[/QUOTE] WIRES ALMOST NEW BUT, NOT CHECKED YET..
I'm unclear (without a schematic) where the capacitor in question is hooked up. Unlike points systems, quality electronic sistems do not need, and rarely use, a capacitor on the C- portion of the circuit. I assume the cap in question is on the battery (B+) side of the module. Unless there are wild supply spikes on B+ (measurable only with an oscilloscope) that the cap is not filtering, the cap should have no effect on the module operation. If there is a loose connection on the alternator/battery line, the alternator may produce high voltage spikes (around 60 to 100 volts) due to current/inductance issues. This could overheat the module from continually trying to clamp the voltage spikes.
A coil short/dielectric issue may allow the coil secondary voltage to arc over to the primary winding (and the module output transistor). This will put a little more stress on the module.
JFB is correct about the coil polarity issue. It takes a higher plug voltage to arc over if the center electrode polarity is reversed (to positive).
Do you know if the ignition coil has OEM specs? A low inductance coil will cause the module to heat up as the output transistor has to deal with higher average current levels (due to the faster current rise time and the current limiting feature built into some modules).
Just some thoughts. Good luck with your debugging!
***it is an assembly and i think i have posted a part number..one side of the ignition module plugs directly into it if i am not mistaken...
Unlike points systems, quality electronic sistems do not need, and rarely use, a capacitor on the C- portion of the circuit.***see above.
**unknown as i have not had a chance to hit the helms yet..however,i do have the replacement in front of me..Unless
***well, as far as i can tell, there exists the possibility of something trashing either the power to the module or the spark enanating from it and since i see no anomalies in the wiring at this time, no shorts or breaks, i have to assume that that could be the culprit, not HAS to be the culprit...
***none...
*** he said that he was going to verify that for me later. however, i put everything on the way it came off. however, that is not to say that it wasn't f__ked up that way when i got the car.
came from the dealer so, i would surmise so..
***i will figure this out or at least carry a suitcase full of modules in my car in the mean time!
