Hard starting cold
Old Jul 14, 2008 | 11:38 AM
dbswany's Avatar
dbswany
4th Gear
Default Hard starting cold
I have a 84 with cross fire injection. It is hard starting cold. Starts great at run temp. I've changed the plugs, wires and temp sensor. I pulled the IAC's out and they vibrate when you turn the key on but the pintle does not seem to really move. Is this normal? I would say they are probably fully extended. Any info would be appreciated. Thanks
