5th gear dragracing?
Old Jul 14, 2008 | 12:03 PM
RRRR's Avatar
RRRR
Default 5th gear dragracing?
Is it ok to use 5th gear dragracing? I running out of rpms with 4.10s
Old Jul 14, 2008 | 12:46 PM
StealthLT4's Avatar
StealthLT4
I don't see why not if you're hitting the rev limiter in 4th...
Old Jul 14, 2008 | 02:13 PM
neat's Avatar
neat
I've done it my car for a few years now with no problems, other than the lost ET due to the extra shift.
Old Jul 14, 2008 | 04:14 PM
mdlfcrss's Avatar
mdlfcrss
gotta be an L98, right?
Old Jul 14, 2008 | 08:50 PM
RRRR's Avatar
RRRR
No lt4 running low 12. I know with nitrous I will run out of rpm
Old Jul 14, 2008 | 10:11 PM
jonecap's Avatar
jonecap
I've trapped 125mph on my LT4 with 4.10s. I don't recommend it...it's turning pretty hard at that speed, but if you are running low 12's, your trap speeds are probably 115-117, which isn't too bad. Get your rev limiter raised a bit. Mine is set at 6,800.
Old Jul 14, 2008 | 10:37 PM
RRRR's Avatar
RRRR
The rev limit is 6400 ish its all hot cam lt4 valve train so I don't know if I could spin it that high. trapping 114
Old Jul 15, 2008 | 12:56 PM
Deakins's Avatar
Deakins
Just check your valve spring pressures and make sure they are up to snuff and you're good to go.
To 5th gear dragracing?
