1996 CE LT1 auto engine idle
Old Jul 14, 2008 | 06:30 PM
ukzo6vette's Avatar
ukzo6vette
Default 1996 CE LT1 auto engine idle
After installing a Hotcam and R/R's I had the PCM recalibrated by PCMforless who appear highly recommended by other members.
The engine now constantly idles at 950rpm which seems very high, the throttle body is clean and I have recently changed the IAC valve and TPS which has made no difference to the idle.
I read somewhere the idle is controlled by the PCM,
so has the PCM been modified to idle at 950rpm due to the mods I have installed or should I be considering other issues, I am sure the stock idle was in the region of 650-700rpm, apart from my concerns on the idle the engine performs well.
Thanks in advance
Old Jul 14, 2008 | 06:49 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
In all seriousness, this would be a great question for PCMforless. IF for example you told them that this car is a daily driver and you do not want any drivability issues, they may well have set the idle speed up higher.
I had this done on mt 95A4 when I went with the hotcam & LT headers because I drive in stop & go traffic every morning. My idle is set to between 900 - 950
Old Jul 14, 2008 | 07:40 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
One quick thought...
after replacing the IAC did you retrain the PCM?
Not sure on your year, but for the 94 LT1, you slightly depress the gas pedal, then start the engine, take foot off gas pedal, let idle for 5 seconds, turn off, for 10 seconds, then restart -- it recalibrates the IAC -- just did a cleaning on our 94's TB and IAC chamber (removed IAC), afterwards recalibrated IAC and idle dropped, so it did work.
Old Jul 15, 2008 | 12:22 PM
ukzo6vette's Avatar
ukzo6vette
Thanks for the replies, yes I recalibrated the TPS as per instructions found on this site, but unfortuantely made no difference, would you think an idle of 900/950rpm was high considering these mods,
Thanks in advance
Old Jul 15, 2008 | 12:27 PM
Rob10R's Avatar
Rob10R
I've been thinkin bout this same upgrade does it make sound different?Do you have any Videos before and after?Thanks
Old Jul 15, 2008 | 12:39 PM
94z07fx3's Avatar
94z07fx3
What idle is the new program seeking? PCMforless will tell you.
Old Jul 15, 2008 | 01:03 PM
ukzo6vette's Avatar
ukzo6vette
Sorry have no video, the work was difficult enough without attempting to video it, but take a look at this website http://shbox.com, this guy is fantastic at what he does, endless amounts of information on the LT1 with pictures that I followed and managed to complete the work without any big issues.
The hotcam has a slight lope to the idle and there is a big improvement in the power, I also installed an MSD optispark, meziere electric water pump (big difference on the running temp) and the LT4 knock module which appears has also made an improvement to the performance.
Old Jul 15, 2008 | 11:18 PM
onebighitter's Avatar
onebighitter
I just had engine rebiult with same mods and have pcmforless chip also. Engine rpm about the same. Ran my first time last weekend. There is a procedure to learn idle in manual but you need a tech 1 computer per book. Next week I plan to put on tech 2 and use the idle learn procedure per service manual and see what happens to my idle. When filling out request with pcmforless did you check the box to set idle at tuners preferance?
Old Jul 15, 2008 | 11:30 PM
96GS#007's Avatar
96GS#007
with the above and as stated by Mr Peabody as well.
Normal to increase the idle a bit to smooth things out. Call or e-mail and I'm sure they'll tell you. You're just wasting time and money until you follow thru with step 1.
Old Jul 15, 2008 | 11:34 PM
Lichen's Avatar
Lichen
With my Hotcam, heads, etc., I idle about 900 rpm. I think that you are fine. Put your stock chip back in and you'll be lucky to keep it running.
Old Jul 16, 2008 | 01:16 PM
ukzo6vette's Avatar
ukzo6vette
Thanks Guys, appreciate your response, PCMforless made the decision on the idle, they should know what the engine would need with those mods,
I am now convinced there are no issues with the idle and will continue to enjoy the car, only problem is the gas price in the UK, current conversion $125 to fill the tank.
Old Jul 17, 2008 | 12:13 AM
Eddie & the Cruisers's Avatar
His chip is the stock one, but reprogrammed. It's a '96 model. Perhaps you meant the stock tune.
My '94: I have done these same mods and a few more, a pcmforless tune and sometimes my idle is 900'ish and fine in gear. Drop in the A/C and it goes down to about 600-650 and too low but you really feel the lope ... and sounds great. The sometimes 900'ish idle drops to 600 in gear w/o the A/C engaged and is too too low, so I think I am having a IAC problem or possibly injectors since it didn't idle smooth before the mods either but was about right (600-650) for the stock cam. I may be having a problem with the A/C ON sensor also, it should raise the idle at ON.
Before and after the mods I had the Hypertech tune on it and it ran great, but wouldn't idle worth a crap, sans the A/C.
Old Jul 17, 2008 | 03:27 PM
JAKE's Avatar
JAKE
PCMFORLESS did the reprogramming on my 96 PCM running a 388 CID and 230/236 CompCams XFI cam. Idle was the same as yours and was what the engine called for.
Bryan can tell you what he set it at. I trust his judgement and experience.
Jake
To 1996 CE LT1 auto engine idle
