ECM question
Old Dec 27, 2001 | 10:23 PM
Kehrer923's Avatar
Kehrer923
Default ECM question
Would a improper idle air sensor setting keep my car from starting?
Old Dec 27, 2001 | 11:06 PM
drive it's Avatar
drive it
Default Re: ECM question (Kehrer923)
I take it you mean the idle air control valve? If it fails and is in the fully extended position it would require you to step on the throttle a bit to keep it running, but shouldn't prevent it from starting.
Old Dec 28, 2001 | 01:04 AM
vader86's Avatar
vader86
a bad IAC usually results in a crappy idle (surging, cuttin out, etc.) yours could be a bad MAF(would set a code) or leaky injector. what exactly is it doing? is it hard to start cold or hot, or both?
Old Dec 30, 2001 | 04:36 AM
GlockLT4's Avatar
GlockLT4
Default Re: ECM question (vader86)
Just to let you know, there is a brand new ECM/PCM forum for C4 guys.. :yesnod: :D
Old Dec 30, 2001 | 05:44 PM
HighHopes85's Avatar
HighHopes85
Idle air sensor-you may be referring to the intake air temp sensor on the bottom of the upper plenum. A faulty sensor or connector will generally tell the engine the intake air temp is -40 degrees C. It usually won't keep the car from starting, but it would make it run crummy. -Matt-
To ECM question
