Coolant mix
Old Jul 17, 2008 | 06:41 AM
conv90's Avatar
conv90
Default Coolant mix
I have a glycol-based coolant on my system. The can of the antifreeze say: Ready to use.
I NEVER seen (here in Italy) some product to mix with water.
All are ready to use. The problem is that I don't know the % of mix in these products.
Is there a way to know the real % ?
When you say you use 50% glycol-based coolant and 50% distilled water, you are also saying that the container say: "to be mixed with water .." or " concentrate for preferred mix" .. ?
-Beppe-
Old Jul 17, 2008 | 06:55 AM
convas's Avatar
convas
You could use a Glycol tester like below although I would expect premixed coolant to have the percentage of glycol somewhere on the label.
http://www.etoolcart.com/index.asp?P...OD&ProdID=2790
Old Jul 17, 2008 | 09:11 AM
c4cruiser's Avatar
c4cruiser
Containers marked "Ready to use" typically implies that the coolant can be installed with no additional water. These mixes are usually a 50% mix of coolant and water. That provides a freezing protection down to -37 degrees F.
Pre-mix containers are easy to us simply because you don't have mix anything. Just pour it in until the cooling system is full. The down side is that they are normally more expensive than the concentrated coolant.
Old Jul 17, 2008 | 10:54 AM
staugur's Avatar
staugur
Pre mixed antifreeze is just another con job thought up by some moron to part you from your hard earned cash.All you are doing is paying for water.Probably aimed at women and the elderly.If you are incapable of making a 50/50 mix and pouring it in you shouldn't have a license.
Old Jul 17, 2008 | 11:11 AM
conv90's Avatar
conv90
I know you are right...
..If only i can find concentrated coolant...
-Beppe
Old Jul 17, 2008 | 11:17 AM
conv90's Avatar
conv90
Default water only
In the summer, is t possible touse 100% distilled water? (or a 90%water -10% antifreeze)
(I never go over 200-205 °F even in "sprinted" driving)
-Beppe-
Old Jul 17, 2008 | 11:32 AM
mr.beachcomber's Avatar
mr.beachcomber
Default Don't forget the water pump seals!
-Beppe-
You could use just water or the 90-10 mixture for summer driving; however, your boiling point would be lowered accordingly. Just remember that most, if not all, anti-freeze mixtures contain additives for maintaining the water pump seals. I believe that Redline's Water Wetter contains these additives and would add it to your mixture.
Old Jul 17, 2008 | 12:15 PM
Kool88vette's Avatar
Kool88vette
Distilled water and a can of water wetter is OK for the summer. I'm doing that now. 50% coolant and 50% distilled water for a cold climate should be fine in the winter.
Old Jul 17, 2008 | 07:58 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
-Beppe-
Not a good idea, why do you think they call it "coolant". It is needed in the summer as well. Just use the premix it is 50/50.
Old Jul 17, 2008 | 08:28 PM
Chatman's Avatar
Chatman
Most of the resistance to boiling comes from pressure, not the mix. Under pressure, a pure water system will not boil at 212 F/100C. I think that you are good to about 240 under 10 lbs pressure. I'm not sure about this, so please set us straight.
Old Jul 17, 2008 | 09:50 PM
convas's Avatar
convas
The coolant also stop's electrolysis is the system which protects the aluminium parts in the cooling system, just water wont offer this protection, not sure what the minimum glycol concentration to maintain this protection is.
Old Jul 17, 2008 | 10:32 PM
Can86Z51's Avatar
Can86Z51
I've been using a mix of 35%coolant-65%water(distilled) for many years, all year round, in a mild(for Canada-Toronto!) climate - in my L86 Z51 Coupe. With a bottle of Redline Watter-Wetter added. No problems - still have my original rad/cooling pieces! One thing I notice - in hot weather in city traffic - coolant temps come down noticeably faster when the main fan comes on. than before with the standard 50/50 coolant mix. Cheers!
Old Jul 18, 2008 | 03:25 AM
conv90's Avatar
conv90
Originally Posted by Can86Z51
......One thing I notice - in hot weather in city traffic - coolant temps come down noticeably faster when the main fan comes on. than before with the standard 50/50 coolant mix. Cheers!
This is my goal.
My car never overheats, but it is slow to cool idleing in the traffic with the two fans running. (no problems when in motion over 35-40 mph).
-Beppe-
To Coolant mix
