Slow battery drain, please help quickly
The BlueDemon is slightly sick and we hope maybe you guys can help. The owner has been out of town for a week, now when he gets back to the car the battery is dead. As for the battery it is the third one he has had in the car in a very short period of time. I think he has something that is draining it. To prove this I want to connect a multimeter inline with the battery and see what kind of current draw it has when the car is off.
For those of you who have done this, how should I go about this? I was thinking to disconnect one of the battery cables (which one?) and simply connect the multimeter between the disconnected cable and the battery. Of course I would need to charge the battery first or I won't be doing any good. My major question is what kind of current drain is normal? I know there has to be something to maintain the radio and such, but certainly not enough to drain the battery that quickly.
The car has done this before, many times. It's just one of those things where if you drive it every day you don't have any trouble out of it so I know the charging system works. It may be good enough for him to leave it that way, but I don't like it. We are going to be adding an MSD 6a ignition and an additional fuel pump, given that extra load I want to make sure that his electrical system can handle it.
One more thing, how would you go about tracking something like that down? I thought about if there was a large drain on the battery we could start pulling fuses and see if one of them gets rid of the drain. If so we know which circuit it's in, but what if none of the fuses kill it?
Thanks guys
Good luck! Let us know what you find!
When you do your amp draw test, make sure your doors are closed and unplug the "under the hood" lights. This will lower the electric draw for your test. Basically, make sure the car is sitting with everything OFF like it would overnight.
I need to pull the fuses as mentioned above and see if something else is 'helping' drain my battery, too. Keep us posted.
David Fulcher
Pete
David Fulcher
