Simplified coolant system (for track use)
Old Jul 18, 2008 | 01:56 PM
ScaryFast's Avatar
ScaryFast
Default Simplified coolant system (for track use)
I am planning to re-do the stock cooling system for simplicity, weight savings, and hopefully a little better cooling.
It looks like I need these two things (or the equivalent):
Fill / pressure tank to replace the black one in the passenger side by the firewall
http://www.hrpworld.com/index.cfm?fo...action=product
or this one
http://www.cantonracingproducts.com/...ion&key=80-200
Plus - Overflow / catch can to replace the plastic one in the nose of the car
http://www.cantonracingproducts.com/...ion&key=80-250
I plan to mount both the the firewall where the heater core was. I assume the catch can needs to be lower than the filler tank - or does the pressure in the system make this irrelevant?
Am I missing anything?
Old Jul 19, 2008 | 01:44 PM
ScaryFast's Avatar
ScaryFast
Nobody?
Old Jul 19, 2008 | 02:22 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The catch can is pressure driven by the cap so it should be OK the only issue I see is coolant in the line will never drip out of it if it is higher. That is if the the new tank is 2 way activated like the stock one is. I see only 1 fitting and a drain valve on the catch can but I imagine you could put a fitting in place of the drain.Looking at the tanks I do not see a return fitting only an overflow.So how is it going to pull coolant back when the engine cools?
Old Jul 19, 2008 | 02:46 PM
Aardwolf's Avatar
Aardwolf
I would leave the stock tank, it's free and I bet it weighs less then those tanks. So I don't see a gain here. Without the heater core the system is already as simple as it gets.
Old Jul 19, 2008 | 02:50 PM
Mojave's Avatar
Mojave
On my car, I removed the pressure tank and lines, and put an inline filler neck in my upper radiator hose. I left the stock plastic, unpressurized tank as is. Worked great for me.
Old Jul 19, 2008 | 08:08 PM
ScaryFast's Avatar
ScaryFast
What does the 2 way activation do?
Old Jul 19, 2008 | 08:29 PM
Redeasysport
If you look at the stock surge tank you see 2 hoses near the cap. One is overflow the other is a return from the oveflow tank. When the engine heats up the cap allows the expansion overflow to go into the tank(upper hose). When it cools the lower hose pulls fluid back into the surge tank from the tank.I believe it has a one way valve in the line. That is why the dipstick in the tank has a full hot and full cold mark.One hose goes to the top of the tank and the other to the bottom.
Old Jul 21, 2008 | 10:48 AM
hookedup's Avatar
hookedup
I did the same thing about 7 years ago, never had a problem
good luck,
Dave
To Simplified coolant system (for track use)
