93 digital dash
Old Jul 18, 2008 | 07:48 PM
tumbleweed's Avatar
tumbleweed
From: "There's a he11 of a lot of things they didn't tell me when I signed on this outfit....... i'm pract
Default 93 digital dash
Put the 93 in the garage for a couple days, went out to start it and the digital display lights up but is blank.....could this be a fuse or something else simple?
Old Jul 18, 2008 | 09:08 PM
tumbleweed's Avatar
tumbleweed
Anyone? Certainly this has happened to someone in addition to me
Old Jul 18, 2008 | 09:24 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Wishful thinking. Obviously it is getting power or it would not light up. Either the connector has come off somewhere or the LCD is shot either way it will be a pita and you will need the FSM to trouble shoot it.You can try pulling codes and see if anything is there to help.
Old Jul 18, 2008 | 09:28 PM
enduro's Avatar
enduro
I'm no expert, but I was at a highline dealer adjacent to a shop where i was waiting on another car recently, killing time, eyeing a black rose 93 coupe, and they had the seat out for some reason, and I inquired about the mileage--the display came up blank orange, BUT, 10 minutes later it was normal. FYI
Old Jul 18, 2008 | 09:29 PM
tumbleweed's Avatar
tumbleweed
Poop ....but thanks
Old Jul 18, 2008 | 10:19 PM
tumbleweed's Avatar
tumbleweed
Well, I slapped the top of the dash a few times and it came back on....guess the diagnosis is a loose connection (somewhere}
Old Jul 18, 2008 | 10:30 PM
Redeasysport
You can pull it and find out where. Probably where it plugs into the display.Worst case it could be a cold solder joint but I doubt that since it has been working this long. Or you can bang it every so often
Old Jul 19, 2008 | 08:11 PM
93_vette's Avatar
93_vette
This is going to work for a while, but it will eventually give out. Had to send mine to Southern Electronics for a repair. 335 bucks later, it works.
Marlon
Old Jul 20, 2008 | 09:31 PM
gdw0717's Avatar
gdw0717
I have the same problem now and then with my 93. I tap on the dash a couple of times and it comes back.
Old Jul 21, 2008 | 12:03 AM
OkieC4's Avatar
OkieC4
I had the same problem with my 91 LCD.
Found this article in the Tech Tips Archives....
https://www.corvetteforum.com/techti...=253&TopicID=2
Checked my LCD pins and found a few loose/worn sockets in the connector. With the help of some small gauge copper wire, I was able to "double pin" the worn ones.
It took a couple of hours, but...No more slapping the dash....
To 93 digital dash
