throttle body bypass
Old Jul 19, 2008 | 01:18 PM
dmukina's Avatar
dmukina
Default throttle body bypass
so today i am going to bypass my throttle body, but instead of using the ecklers coolant connector i am planning on just capping the coolant lines where they start. any one see a problem with this? just checking to see if i might miss something that could cause me a problem. It just seems like capping them is easier than connecting lines that are usless.
Old Jul 19, 2008 | 02:58 PM
garkahn90's Avatar
garkahn90
I believe you need the coolant line to supply coolant to the heater(?). I recently did the by-pass by just running a single hose from the heater to the intake manifold fitting.
If infact that line isnt needed then I would do what you are thinking of doing. It would help clean up the engine compartment.
Old Jul 19, 2008 | 03:22 PM
94z07fx3's Avatar
94z07fx3
For your '92,
1996 upper radiator hoses are one piece. That eliminates the T fitting.
Generic heater hose will eliminate the other T.
To throttle body bypass
