1996 Lt1 Tps ........help?
Inspect all vacuum lines. Inspect air ducts. Inspect IAC.
Just before it started, have you done something that could have allowed or dislodged some dirt into the intake (e.g. changed air filter, cleaned TB or MAF) or gone through a really dusty area?
If so, a small bit of dirt could have hung-up the IAC.
Not sure about the 96 LT1, but for the 94 LT1, there is a simple way of recalibrating the IAC.
1. Before starting the car, depress the gas pedal slightly.
2. start the car, and immediately take your foot of the gas pedal.
3. Let the car idle for 5 SECONDS.
4. turn off the car for 10 SECONDS.
5. restart the car.
6. the PCM will readjust the IAC to the correct idle.
If this does not fix the problem, consider starting simple --
Consider cleaning the Throttle-Body and Mass Air Flow sensor.
use products specifically designed for both (e.g. CRC TB cleaner and CRC MAF cleaner) as more harsh cleaners can damage coatings or the sensor wire.
btw, no need to remove the TB, but do consider removing the IAC and cleaning its chamber.
Do prevent leakage of the cleaner out of the TB down onto the OPTI.
ALso, the car may act like it is 'flooded' after cleaning the TB, so be sure your battery is charged, just in case.
Thereafter, after the car runs a bit, try resetting the IAC again, it might then solve your problem.
5. restart the car.
If this is something that started all on it's own AND not after another mod/repair --I'd guess dirty IAC valve.
