Belt Tensioner...
Old Dec 28, 2001 | 03:51 PM
puck's Avatar
puck
Default Belt Tensioner...
I swear, I think winter is the month for my 'vette to hit me in my wallet! :(
Anyways, I just finished replacing the valve covers, the gasket, the power steering reservoir, and having the windshield and seal replaced. Now, the voltage in my car is incredibly low. Normally it runs [at bare minimum] at 13.8, and most of the time it's in 14.0+ range. Now, the day I get the car back from having the power steering reservoir done and the windshield and seal replaced, the voltage is at max 11.1. With the accessories on it runs at maximum of 10.6. The battery is new and has been great [I believe it's in the 1000 CA range] and the serpentine belt is fine. My question, does the low voltage [although it does start up fine but only stays in the mid 10 or low 11 range] indicate a bad alternator? Or is it possible that the belt isn't tightened enough? Anyone have any ideas?
-Steve
Old Dec 28, 2001 | 04:03 PM
EricVonHa's Avatar
EricVonHa
Default Re: Belt Tensioner... (puck)
Put a meter on it just to be doubly sure. But if the alternator is spinning... it should be throwing a charge. If you run the car for several minutes and the charge never goes above 12vdc, then you're alternator is probably doa. Could be another gremlin, but doubtful. Internally regulated alternators are an easy thing to test and replace!
Old Dec 28, 2001 | 04:09 PM
Jsailor24's Avatar
Jsailor24
Default Re: Belt Tensioner... (EricVonHa)
I had about the same thing happen. It hels 11s for a while then within 10 miles it was dead. it was the alternator-- i have an almost new batt. also.
Old Dec 28, 2001 | 08:15 PM
jfb's Avatar
jfb
Your alternator has no output. First check to see if the plug in connector on the alternator got bumped and is not fully seated. Next, with the engine off, there should be battery voltage on the big red wire on the alternator, if not, someone accidently shorted this terminal to ground when working on the car and blew out the fusible link in the red wire which goes to the jump start terminal next to the battery. Good luck.
Old Dec 28, 2001 | 09:03 PM
87-2NV's Avatar
87-2NV
I was getting the same readings after replacing my battery. Pulled the alternator took it into Auto Zone and they checked it there. it was bad...
To Belt Tensioner...
