Won't start
Old Jul 20, 2008 | 03:55 PM
gnkjoy's Avatar
gnkjoy
Default Won't start
I'm trying to help a neighbor lady with her 95 automatic. The starter doesn't engage. It worked fine last time she drove it. Now when you turn the key to start position you can hear a click but no starter engagement. Charged the battery and also tried jump starting. Same thing, just a click. If if happened on my 71 I would immediately suspect the starter solenoid. However I'm not familiar with the later models with anti-theft and computer controls.
Old Jul 20, 2008 | 05:05 PM
staugur's Avatar
staugur
You are probably suspecting correctly but you may want to check the earth straps as well.
If you are getting a click it's not the VATS system.
Old Jul 20, 2008 | 06:04 PM
jtoombs's Avatar
jtoombs
well this prolly dont help much but my car was having similar problems but the starter wouldnt even click and it was the security fuse that blew, so i would be sure and check the fuses
Old Jul 20, 2008 | 06:09 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
You know the drill tap the solenoid with a hammer if it starts there ya are....
Old Jul 20, 2008 | 08:20 PM
gnkjoy's Avatar
gnkjoy
OK, I'll try that. Can you get at the solenoid on a 95? I haven't enven jacked it up and looked underneath.
Old Jul 20, 2008 | 08:32 PM
Y-ME's Avatar
Y-ME
If there is a click it's not the security system. I don't know if you can get a separate solenoid, I have not done a solenoid only since like 1988. Might as well just replace it all as long as you taking it apart. But first make sure th battery is fully charged and the terminal s are clean.
To Won't start
