head lights out of sequence
Old Jul 22, 2008 | 10:55 AM
tutster's Avatar
tutster
6th Gear
Default head lights out of sequence
put new bushings in the left hand side headlight motor....now when i turn on the lights, one side raises, other side lowers.... tried ajusting,but doesn't help.....any answers would be gtreat.
Old Jul 22, 2008 | 11:02 AM
StealthLT4's Avatar
StealthLT4
Haha. I can't help, but that vision in my head is just funny
Old Jul 22, 2008 | 11:05 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Did you take out the entire motor assembly, or did you replace the bushings with the motor assembly still installed on the car?
Old Jul 22, 2008 | 11:08 AM
schrade's Avatar
schrade
Yeah - just think if he could pull the stops in both, and they kept spinning 360' opposite direction! That would be a hit at the vette shows!
Old Jul 22, 2008 | 11:10 AM
tutster's Avatar
tutster
6th Gear
i removed the motor.....think i might have got it out of time....how do u correct this. ?
Old Jul 22, 2008 | 11:13 AM
schrade's Avatar
schrade
I'm guessin' your motor drive shaft needs to be rotated 180'.
I imagine also that it won't rotate one way, but only the other...
tutster's Avatar
tutster
6th Gear
removed the motor...guess i have it out of time...how do you correct ?
Old Jul 22, 2008 | 11:14 AM
tutster's Avatar
tutster
6th Gear
thanks for the info....i'll give it a try
Old Jul 22, 2008 | 11:23 AM
tutster's Avatar
tutster
6th Gear
it rotates both ways....
To head lights out of sequence
