Fel Pro Gasket
Old Dec 29, 2001 | 09:53 AM
WHRITZY's Avatar
WHRITZY
Default Fel Pro Gasket
Can someone tell me the Fel Pro part number for stock intake manifold gasket on 90 L-98? thanks!
Old Dec 29, 2001 | 02:10 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: Fel Pro Gasket (WHRITZY)
Whritzy,
I believe that it is a felpro gasket number 1204. That is what I remember installing when I put on the mini-ram. I am running the later model l-98 heads with no port work and the gasket fit perfectly. I know my mini-ram was set up to match a 1204 and I was told that this was the original port size for these heads. If you wanted to doublecheck you could just call tpis (952) 448-6021. Hopefully this helps.
