Need help diagnosing wheel shake
Old Jul 24, 2008 | 11:31 AM
dnut24's Avatar
dnut24
Default Need help diagnosing wheel shake
I have a 95 coupe and have been experiencing a lot of wheel shake when hitting bumps. Basically it feels like the wheels are loose and vibration transfers to steering wheel pretty violently. When I had it aligned Firestone said that the outer tie rod needed to be replaced. It looks fine to me. But when I changed my oil last weekend I hugged the wheel as someone advised and I could physically move both wheels with load taken off and move them side to side. A good bit of play in them. So this is obviously my problem as to when I hit a bump.
My question is, is it the outer tie rod ends, or something else? To me the tie rods are solid and bolted down, i can't see that effecting wheel play.
thanks
Old Jul 24, 2008 | 01:03 PM
sand1's Avatar
sand1
Cruising
if you can move the wheel by holding front and rear of tire have someone watch steering linkage to see whats loose. if you have movement by holding top and bottom of tire probably ball joints or wheel bearings. hope this helps sand1
Old Jul 24, 2008 | 01:08 PM
86GoldProject's Avatar
86GoldProject
it could also be the inner tie rod ends.. while you are shaking the wheel you need to look and see where the play is, sometimes it helps to have another person either look or shake the wheel while you look.
Old Jul 24, 2008 | 01:42 PM
dnut24's Avatar
dnut24
ok thanks I'll do that. It didn't seem to have any movement from top and bottom, just from holding it on the sides. I'll have to have someone shake it while I look i suppose.
Old Jul 25, 2008 | 04:56 AM
Weav's Vet's Avatar
Weav's Vet
My '96 had that same play. It was the outer tie rods.
Old Jul 25, 2008 | 08:02 AM
dnut24's Avatar
dnut24
cool, thats what Firestone said, but I just didn't see how. They want $200 a side, but the part is like $30. Any tricks or things I need to look out for? Looking at it, seems simple enough. Remove end from wheel spindle, then unscrew from tie rods. Do i need to make any measurements or anything? I'm sure I'll need an alignment after it as well.
Old Jul 25, 2008 | 09:57 AM
anesthes's Avatar
anesthes
The part is like $70 last I checked. They are freaking expensive on the vette.
-- Joe
Old Jul 25, 2008 | 10:50 AM
sand1's Avatar
sand1
Cruising
count thread turns out then turn new one in same amount. this will get you close, you still need a toe adjustment after
Old Jul 25, 2008 | 12:27 PM
dnut24's Avatar
dnut24
sounds cool Sand.
as far as price I found them for like 40 bucks.
http://www.parts.com/oemcatalog/inde...layCatalogid=0
Old Jul 25, 2008 | 12:42 PM
Weav's Vet's Avatar
Weav's Vet
You can probably just go to NAPA and get them, I did. Don't remember what they cost but it wasn't much.
The only problem I had was unscrewing the old ones. You may have to heat them up with a butane torch a little to get them to turn lose. Could have just been my car though. No telling when it was aligned last before I got it. A piece of tape wraped around the tie rod will get it back close to where it was. Try not to let the rod turn. That turns it in the inner tie rod on the steering rack. Make sure you grease the new ones.
Old Jul 25, 2008 | 04:31 PM
sonny@intermaxnetwor's Avatar
I'm doing mine now, Tire dealer said outer tie rod but when I checked it there was excessive play in the lower ball joint, corvette recycler.com has great prices on OEM factory GM parts, he sells the whole A-Arm with the ball joint installed and new bushings for what it would cost for just replacing the ball joint, his factory GM tie rod ends are $39.00 each.
Old Jul 28, 2008 | 08:42 AM
dnut24's Avatar
dnut24
thanks for the tips, I'll look into that this weekend.
To Need help diagnosing wheel shake
