87 Vett with issues...
Old Jul 25, 2008 | 04:14 PM
IcantDo55's Avatar
IcantDo55
Default 87 Vett with issues...
Working on a friends 87 Vette auto, 160K. Was running fine and while cruising it stuttered and started loosing power. It now starts runs and revs up fine, but you put it in gear under load it does the same thing.
These are the parts that have been replaced trying to solve the problem:
Cap
Rotor
Wires
Plugs
Coil
Fuel Pump
Filter
O2
TPS
MAF
Ignition module removed and tested at Autozone, good.
Sounds to me to be a timing issue?
HELP
-Mike
Old Jul 25, 2008 | 05:02 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
1st - get a FSM
2nd - use the search function
3rd - quit throwing parts until you know the issue
4th - check for codes
Old Jul 25, 2008 | 05:04 PM
schrade's Avatar
schrade
Originally Posted by vinnies87
1st - quit throwing parts until you know the issueget a FSM
2nd - quit throwing parts until you know the issueuse the search function
3rd - quit throwing parts until you know the issuequit throwing parts until you know the issue
4th - quit throwing parts until you know the issuecheck for codes
fixt!
Old Jul 25, 2008 | 05:05 PM
IcantDo55's Avatar
IcantDo55
1st - get a FSM
Its not my car, just got to be the lucky one working on it. All parts were installed by owner.
Search came up with all the parts that have been replaced before.
No codes.
Old Jul 26, 2008 | 12:14 AM
jfb's Avatar
jfb
What do you mean by, "...put it in gear under load and it does the same thing"? When you rev an engine, the engine is under load. You can check the spark timing with a timing light. At night, defeat the underhood lights and engine idling, look along each plug wire for sparks. You shouldn't see any. Replace any plug wire looms that are broken or missing and dress plug wires to not touch metal. Plug wires have microscopic pinholes in them and if touching metal, will spark there instead of at the plug gap. Measure the fuel pressure at the shrader valve on the right side fuel rail at its rear. It should be about 40 psi and stay there when you put it in gear and load the engine.
Old Jul 26, 2008 | 01:33 AM
IcantDo55's Avatar
IcantDo55
What I mean is, when its in neutral or park it revs up fine but in gear trying to accelerate it bogs down. Hope that clears it up.
Old Aug 2, 2008 | 01:15 PM
IcantDo55's Avatar
IcantDo55
Went over the car again and fixed a few small vacuum leaks but nothing major. Than let it idle in the driveway in 95* temps for an hour, all is fine. Took it out for a drive and after about 3 miles of low speed driving water temp hit 209* and it lost all power??? Barely made it home at idle.
My opinion is that it seems fuel related because it did not have the violent cutting out of a spark related problem. Felt down on power like it was out of fuel. Is there an easy way to monitor fuel pressure while driving?
Ideas please?
Old Aug 2, 2008 | 01:43 PM
schrade's Avatar
schrade
Ideas please?
Sure is... 4rth fuel pressure test is pedal down test - FP gauge on a long hose taped to windshield, and pedal down.
This is for L98; I'm not sure what spec is for the test. Search the forum my posts for TUNING TPI ARTICLE...
Old Aug 2, 2008 | 02:58 PM
IcantDo55's Avatar
IcantDo55
Did that, and it lost fuel pressure. Think the pump bad. Or something running the pump. New pump, go figure. Can a relay be an intermittent problem when it gets hot? Is there some other electrical issue I should be looking for? Or should I just replace the pump again?
Old Aug 2, 2008 | 03:42 PM
deerkill10's Avatar
deerkill10
check injectors
Old Aug 2, 2008 | 06:02 PM
IcantDo55's Avatar
IcantDo55
Problem solved. And for all you on the edge of your seats....The guy who installed the fuel pump put the sock on wrong and it fell off and he also used MUCH to MUCH RTV to seal the fuel pump into the tank and it dripped into the fuel. The fuel pump with out sock installed had about a 1/2" screen to draw through and got clogged up with a chunk of RTV causing it to run like crap. So after cleaning the tank out and replacing the sock it runs great again.
Thanks for all the help!
Old Aug 2, 2008 | 10:59 PM
Southern Comfort's Avatar
Southern Comfort
Change the fuel filter before you yank the thing apart.
Old Aug 2, 2008 | 11:05 PM
Road Agent's Avatar
Road Agent
Originally Posted by Southern Comfort
Change the fuel filter before you yank the think apart.
What is a think?
Old Aug 2, 2008 | 11:06 PM
Southern Comfort
Originally Posted by Road Agent
What is a think?
Its a rare version of Thing. Only found on Saturday nights.
Old Aug 3, 2008 | 01:23 AM
schrade's Avatar
schrade
Gasoline turns RTV into soft JELLO. It will swell, bunch up, and literally fall off metal whole, that it otherwise would have taken a torch to get off.
To 87 Vett with issues...
