I am having problems with a 1992 Vette on the electic or charging sys.
Old Jul 25, 2008 | 05:54 PM
covette777's Avatar
covette777
Default I am having problems with a 1992 Vette on the electic or charging sys.
Hi buddys, this vette is my first car that I had have (thanks God!!) so is hard for me....I hardly know how to check the engine oil so this is the deal... the car need the gas pump...so they changed....the I took it to the electrician so the door panel get fix..and the glass and back glass trunk now ...work..., but it does not start may could be a short circuit.... I have not replace the spark plugs. Yesterday I moved back the seat with the console buttons, does any of you know if it's the alternator, starter?? ;another thing...the headlights are getting stock when I turn it on...guys thanks alot ahead....I appreaciatte you advices.
Carlos
Old Jul 25, 2008 | 08:32 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Is the engine turning over?
Are there any codes?
Is there fuel in the tank?
Need all the info you have, is the car trying to start and is there spark at the spark plugs?
Old Jul 25, 2008 | 09:09 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
....and fill out your profile as well as type in sentences so we can try and understand what you are asking. Also include location in case someone nearby can help you. You don't sound like a DIY guy. "they" does not mean a thing to us tell us who is working on your car.
Old Jul 29, 2008 | 03:21 AM
covette777's Avatar
covette777
Default thank you for your help
-the engine does not turn on
-at the dash board appear some ligths like check oil, check engine...
-it does have fuel
-I have not change the old spark plugs....
-it does not start....I think could be the starter
any advices?? guys'
for Redeasysport: I will fill my profile soon...and sorry buddys for my speling & grammar, english is my second language I would like dominate as well as spanish I will try my best to make myself understandable by the way...what means ? "DIY"
I would like to have more experience on cars but this Corvette is my 1st car that I ever had have....Im happy I praise the Lord thanks God!!
God bless you all, thank you guys for your time & help
-Carlos
Old Jul 29, 2008 | 10:01 AM
Redeasysport
So you say it does not turn over the starter correct? Do you hear the fuel pump when you turn the key on? Do you have the factory service manual? If you do not hear the fuel pump come on when the key turns on it sounds like the VATS(vehicle anti theft) ckt. Clean off your key and try again and listen for the fuel pump to kick on.DIY is Do It Yourself. these cars are complicated and hard for someone who has never worked on a car to fix.
Old Jul 29, 2008 | 05:29 PM
covette777's Avatar
covette777
No it does not start is like dead, I had already taken to the shop.......they already changed the fuel pump and the tank was cleaned...I wil take theVette to the electician shop so they could find out whats happenig.....thank you for yout advices Redeasysport
Old Jul 30, 2008 | 04:15 AM
toptechx6's Avatar
toptechx6
I can appreciate the language barrier, but Redeasysport had a good suggestion. If you fill out your profile other members can tell where you are located and someone may live close enough to help. Good luck.
To I am having problems with a 1992 Vette on the electic or charging sys.
