Opti-spark Moisture Eliminator???
Old Jul 29, 2008 | 02:35 PM
Randy Munson's Avatar
Randy Munson
Default Opti-spark Moisture Eliminator???
Hey C4 brothers! There's a 92-93 Opti-Spark Moisture Eliminator being sold in my Corvette Central catalog(catalog 4E, page 54) that claims to "keep the moisture out of the module with a permanent seal". Sells for $24.95. Worth looking into, or should I just open my driver's window and let the $25 bucks fly out as I roll down the highway??? Much obliged.
Old Jul 29, 2008 | 04:04 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Got a link? You could probably do the same with some Permatex "The Right Stuff" RTV if it is just a seal.
Looking online that has been discontinued. They do have a modified Opti for 92-94 but I don't like what they did the one in my pics uses a 95 cap they did not do that looks like they drilled a 93 cap.
Old Jul 29, 2008 | 04:37 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Check this out
http://www.corvettefever.com/howto/16758/index.html
Old Jul 29, 2008 | 07:31 PM
Redeasysport
Old Jul 29, 2008 | 10:50 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Originally Posted by Redeasysport
I don't know about this. I tried this in 2003 with my 92 and thoe "T" vacumm fittings rubbed against the balancer hub and I ended up taking them off. I wasted money and time.
Did you do this? Did it work?
Old Jul 30, 2008 | 12:29 AM
2012 coupe's Avatar
2012 coupe
Default Opti kit
I had the shop that works on my vette put something like that on my 1992 A/T about 8 years ago and the Opti is still running great, in fact so is the stock water pump also. Added a Custom built Griffen Race, 3 row radiator at the same time. Runs about 174 degrees on a 80 degree day or so on the freeway, in traffic, 193 and fans come on and cools to 180 degrees. Ed Wright custom chip in it. 160 degree thermo. It has about 130,000 miles on both of them. 160,000 on vette. I drive it. Just make sure you route the two hoses around everything that moves. I can not complain. Drive it 150 miles a day round trip to and from work. A couple of weeks ago I thought the Opti was shot, but turned out to be the coil and Ing module. One of these days MSD.
Old Jul 30, 2008 | 10:53 AM
Redeasysport
Yes I did it and it worked. I should have nipped a bit more off the "T" fittings and JB Welded it better as I did have to do it later.
Old Jul 30, 2008 | 02:01 PM
93lt1fun's Avatar
93lt1fun
The vacuum lines (2 were added) is what was enhanced on the 95+ Opti-spark. 92-94 can be upgraded / converted but, requires other new parts and expense. I've done it and works great! I'm sure that there is an article on the Forum related to this or I can dig up the P/N's required for the swap.
To Opti-spark Moisture Eliminator???
