Does make a difference on keeping the incoming air cooler, the more cool the more dense better performance! Unless you might be drinving it this winter in Alaska you can go ahead and re-route it.
Good Luck wro87
I found that after by-passing the coolant hose running into the throttle body my plenum is much cooler. It also makes it easier to remove as you are not dealing with the hose & coolant. From what I understand it was only added to prevent freeze up for areas where the weather is sub freezing for extended periods of time.
Ok, I'm inclined to believe that, so I ask this? All hypothetical of course.
If you plumbed up a small heater core [filled with a glycol], and stuck it in the air stream [or better with the Aux fan blowing on it] and added a little circulation pump would the the weight be worth the "COOLED" throttle body??
TJM
Reason: mispelling
TJM
With that setup you would only cool down to ambient temp. The incoming air is already at ambient temp.
You only get something like 1 hp for every 10 degrees cooler. Most likely the cooler would block more air and you would loose more hp than you get from the cooling.
