The best solution is to remove the drive gear and shaft and plug the hole. This requires removal of the timing cover.
Some folks just leave it in place.
Do you want to do it the right way or the easy way?
Is the backside of the drive/gear shaft into a bushing or bearing.
pictures in repair manuals make it look as tho the timing chain
and gear would have to be removed. Short answer, the easy way
if it is safe and reliable.
I wasnt comfortable leaving it in place and removed it. I was also replacing my opti at the same time as well. Its a PITA but I have more peace of mind this way since I spin my motor to 6700 on a regular basis. I was able to lossen the cam gear and pull the splined shaft/bearing for the water pump drive off at that time. If you go that far its not really any more work for a cam swap, something to consider.
Mine is a new crate LT4 so I will not be removing the Opti or cam for a while. I'm kinda uncomfortable with leaving the shaft, but if it's supported on both ends and is just along for the ride i'm tempted to let it wait...unless someone has had a problem leaving it in...Thanks for the input.
There lies the problem I had. The drive shaft is not supported at both ends and "along for the ride". Once you remove the water pump its only supported by the bearing that is pressed into the block at the lifter valley. If the engine is out of the car go ahead and remove it. Its very simple if the motor is out of the vehicle. JMO.
My computer has been down for a couple days. Thanks for your input.
There is not a bushing in the timing chain cover???
I do not remember, but I can tell you that I got all of my freeze plugs from Advance Auto Parts, they have a really good selection "for some reason"
just mock it and see, if it is just a hair to big for the hole then thats it and go get the same size, if not, they sell them in fractions.
All of the LT motors are single chain gears because of the space constraints from the water pump drive gears, so if you do away withe the afore mentioned parts you can go to a double roller style chain, on the 96 model it has a relucator ring in front of the crank timing gear and a sensor that is a pick up for spark knock, you should be able to see the plug it is on the bottom passenger side of the timing cover.
