Oh! the noise.
Old Jul 31, 2008 | 07:12 PM
dlb435's Avatar
dlb435
Default Oh! the noise.
I have a stock 85 TPI and the noise from under the hood is terible. It was worse but so far I have replaced the oil pressure sending unit, the belt, the AIC, the TPI, the knock sensor, the plugs and the fuel injectors. I have a smog pump coming. The AC compressor is VERY loud at idle but runs good at 1200 rpm and above. I have played with the thottle body settings and can finally run without getting any "check engine" lights. What do I need to do to get this engine to run smooth and quiet?
