Injector resistance
Old Aug 1, 2008 | 04:17 AM
IslandVette808's Avatar
IslandVette808
Default Injector resistance
Will checking the injector resistance only tell you if the injectors are working properly or could it also tell you of a leaking injector? I suspect a leaking injector on my car and am just curious if doing this test will help confirm that. Thanks!!
Old Aug 1, 2008 | 11:29 AM
Sweet 90's Avatar
Sweet 90
Check this video out or pm Jon at Fic or he will probably chime in
Jim
http://forums.corvetteforum.com/show....php?t=2055839
Old Aug 1, 2008 | 12:14 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
checking the resistance of the injector will tell you if the coil that accuated the valve is good. If the ohm reading is low (below 12) the injector is on its way out and probablly is not working 100%. if it is below 10 its time for injectors. Leaky injectors are another test. But, check resistance first.
To Injector resistance
