Gen7 datalogging
Old Aug 1, 2008 | 03:39 PM
weez58's Avatar
weez58
Default Gen7 datalogging
Question for the Gen 7 people,
I'm looking at my datalog graphs and I'm trying to figure out what the O2 feedback value would be if the actual AFR is equal to the AFR value in the table. The numbers I'm seeing range from .93 to 1.08. Does 1.00 mean no fuel is being added or subtracted? Do numbers above 1.00 mean fuel is being added and if the number is less than 1.00 then fuel is being subtracted?
Thanks,
Bob
Old Aug 3, 2008 | 01:34 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Thanks,
Bob
Weez, Yes, you are data logging "closed loop fuel control coefficient" Depending on what version Gen VII you have, it will vary above and below 1.00 to the percent you allow in the correction limit table(s).
Bullshark
